Car preheating
Sun Nov 01, 2015 3:58 pm
RAID5 offline
Car preheating
Hi forum!
I need help!
I'm trying to build a automation to heat my car during cold winter mornings.
My goals are following:
1. Set independent departure time for every day
2. On/Off (Enable/disable) independent for every day
3. Start the heating depending on outdoor temperature
If the temperature is +10C +5C then the heater need to start 1 hour before departure
If the temperature is +5C +0C then it need to start 2 hour before departure
If the temperature is -0C -10C then it need to start 3 hours before departure
If the temperature is -10 -20 then it need to start 4 hours before
And finally >-20 5 hours before departure
Nr 2 was easy, just create a true/false variable for each day.
Nr 1 I'm not really sure how to solve, I need a function similar to an alarm clock. Where I can set a time easy with up/down arrows for minutes and hours.
Nr 3 is even more tricky. I need to calculate time remaining to departure and depending on temperature start in time. I leave at earliest 05:00 in the morning for work, I guess I can set a count down timer at midnight every night, but I still down know set the departure time in Nr 1.
Some one more cleaver then me or more knowledge in scripting that can give me some help.
RAID5 "A happy Swede addicted to automation"
Mon Nov 02, 2015 1:37 pm
Re: Car preheating
Someone beat you to it:
viewtopic.php?f=107&t=14891&p=103986&hilit=Preheat#p103986
Mon Nov 02, 2015 4:51 pm
andarv offline
Re: Car preheating
That script solves the basic with preheating depending on departure.
It takes ETD from a variable, if you don't like to modify the script to much u could use a schedule to update the time. Otherwise it won't be independent.
To set time on a control page is above my knowledge, I have tried. Right now I use pop-up on the iPad.
Skickat från min HTC One_M8 via Tapatalk
Mon Nov 02, 2015 10:00 pm
Re: Car preheating
What about pre cooling
Thu Jan 14, 2016 5:32 am
andarv offline
Re: Car preheating
This morning it was -22C so the option to cool down the car isn't that appealing.
Where I live it's not really a priority any time of the year :)
But one option would be to roll down the windows with a relay?
