[ANSWERED]: About Custom Device States
Mon Oct 26, 2015 6:41 am
wickey offline
Im here again with another question :)
for my custom device I am having custom status as below.
<States>
<State id="playStatus">
<ValueType>
<List>
<Option value="not_playing">Not Playing</Option>
<Option value="playing">Playing</Option>
</List>
</ValueType>
</State>
<States>
Since we can't have spaces in option value, I have added the "_". When plugin detects status change I update using
device.updateStateOnServer("playStatus", "not_playing"). Then plugin works fine, but in custom states of that device , value shows as "not_playing" with underscore. In Indigo Touch also it shows as the same way. I don't like it much. How can I get "Not Playing" rather than showing "not_playing".
device.updateStateOnServer("playStatus", "Not Playing") gives "invalid enumeration value" Error.
Mon Oct 26, 2015 6:55 am
RogueProeliator offline
Re: About Custom Device States
The way to change the display that is shown in the State column of the Mac client and in Indigo Touch is to use the uiValue parameter when updating the state:
dev.updateStateOnServer("playStatus", "not_playing", uiValue=u'Not Playing')
Note that all triggers and actions and such will still use "not_playing", this just affects what is shown in the display field(s).
Adam
Mon Oct 26, 2015 11:48 pm
wickey offline
Re: [ANSWERED]: About Custom Device States
Thank You very much.. It is working for ui values in indigo touch and in status column in indigo mac client, but under Custom Status box ( in indigo mac client ) still shows not_playing.
Is it expected behaviour?
Tue Oct 27, 2015 3:36 am
Do you mean here?
Screen Shot 2015-10-27 at 4.21.34 AM.png (27.1 KiB) Viewed 1925 times
As you can see, it is possible to have spaces in a custom state value. What I think you are seeing is a Python idiom for parameter values. Because you are establishing a list element In your device's XML, you are setting the default parameter values for a method call and (as far as I recall) spaces are not allowed for parameters.) in other words,
maximumFoo(self, parameter1="this_is_allowable", parameter2="this is not allowable")
"not_playing" is the actual value of the state, and that's what is being displayed in the Custom Device States window. As far as I know, it isn't possible to display the uiValue in the Custom States window.
Dave
Tue Oct 27, 2015 7:57 am
wickey offline
Yes I meant there.
Yes it is possible to have states with spaces when the value type is a string. But when it becomes list it was not possible.
Anyways, I am satisfied with UiValue.
Thank you very much for quick replies and your comments helped me lot.
Tue Oct 27, 2015 10:20 am
In a word, yes. Enumerated state types aren't yet really used well, and this is one area where it falls down a bit.
