Hi Mike!
Wow, great news!
Can't wait for it, can I donate some bucks or a beer over Paypal?
Best,
yassi
File "plugin.py", line 1414, in colourPick
File "plugin.py", line 131, in presetColours
<type 'exceptions.IOError'>: (2, 'No such file or directory', '/Library/Application Support/Perceptive Automation/Indigo 6/Preferences/Plugins/RGBColours.txt')
Fibaro Light Manager RGB
DaveL17 wrote:Just getting around to test driving the plugin. Been distracted working on a few updates myself.
Love the plugin Mike. It's coming along well. A couple things I noticed, however:
1. Because I live my life in the .../Plugins folder, I of course copied the RGBColours.txt file to the wrong folder. I wasn't paying attention. This resulted in an exception to the log:At a minimum, I think this would be a candidate for a trap, but I'd suggest a different route. You could make this file a component of the plugin package, and then you could get rid of the step requiring a separate install of the RGBcolours.txt file altogether. Then, if you later wanted to add more colors, you could update the file with the next plugin release.
- Code: Select all
2. I installed the plugin using an Indigo client that is not on the server machine and this doesn't work with one of the features of the plugin UI (the color picker.) No problem, but I'd suggest a note in the UI that alerts the user to the fact that the colour picker is going to appear on the server machine and not the client machine. I'm slow, so it took me a minute to figure this out.
3. It was a race to pick a color with the color picker. If I didn't pick very quickly, the plugin would timeout.
4. When I open the device configuration dialog, I get about 100 of these:I'd suggest getting rid of this logging, or at least adding a debug level to it.
- Code: Select all
5. There is no number 5.
6. You repeatedly misspelled the word "color".
Really nice job. Keeping it going Mike!
Dave
Z-Wave received "Alex Duetto" power load to 3.6 W
Z-Wave received "Haydn Bed - Motion" status update is on
Trigger Haydn under bed
Action Group Haydn Reset
Fibaro Light Manager Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1649, in switchOn
<type 'exceptions.KeyError'>: key colourSelect not found in dict
Z-Wave received "Haydn Bed - Luminance" sensor update to 1%
Z-Wave received "Haydn Bed - Temperature" sensor update to 21.0 °C
WUnderground Getting weather data for device: Current Weather
Z-Wave received "Haydn Bed - Motion" status update is off
Schedule Tado Information update
Schedule Update Time
Schedule Update Timers
Schedule Update Coffee Machine timer
Schedule Energy Usage
Script rightNow 2015-10-15 18:30:01.154850
Chockymonster wrote:I'm seeing an error in my logs every so often, I'm not 100% sure what's causing it though.
- Code: Select all
It seems to be when an action group fires that turns on an RGB controller using the plugin.
