Yamaha RX Plugin - a/v receiver control
Mon Dec 09, 2013 5:44 pm
discgolfer1138 offline
[MODERATOR NOTE]: this topic is a legacy topic and is locked (we leave it here for historical purposes). Please create a new topic for any issues.
simple control of Yamaha RX series a/v receivers.
Requirements:
    Indigo 6 or later (pro version only)
Installation Instructions:
    Download latest release here
Actions Supported:
    Set Volume
    Increase Volume
    Decrease Volume
    Set Mute
    Toggle Mute
    Set Power
    Toggle Power
    Set Sleep
    Get Status
States Surfaced:
    power (On, Standby)
    sleep (Off,30,60,90,120)
    volume (int)
    mute (bool)
    input (sirius, xm, tuner, multi_ch, phono, cd, tv, md.cd-r, bd.hd_dvd, dvd, cbl.sat, dvr, vcr, v-aux, dock, pc.mcx, net_radio, rhapsody, usb)
The source code is available for collaboration on GitHub
Bugs can be reported here
Indigo 6.1.0 | Mac Mini | OS 10.10.3 (Yosemite)
Fork Me on GitHub!
Thu Jan 23, 2014 3:53 am
col offline
Re: Yamaha RX Plugin - a/v receiver control
Hi, thanks for the plug in but the only thing I can do is put mx RX-V675 into standby, everything else gets an error message
Yamaha Rx Receiver Error Error in plugin execution ExecuteAction:
File "plugin.py", line 170, in setPower
File "plugin.py", line 105, in putPower
File "plugin.py", line 20, in xmitToReceiver
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 124, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 381, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 399, in _open
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 360, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 1118, in http_open
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 1093, in do_open
<class 'urllib2.URLError'>: <urlopen error (60, 'Operation timed out')>
Sat Jan 25, 2014 8:31 pm
BenX10 offline
Hi discgolfer1138 and thanks for sharing this!
I've a problem with the plugin: Right after enabling the plugin I get "exception in deviceStartComm(RX-V775): 'NoneType' object has no attribute 'text'" in the event log. Yamaha's web control works and so does this little php script:
<?php
function send_to_host($host,$method,$path='/',$data='') {
    $method = strtoupper($method);
    $fp = fsockopen($host, 80) or die("Unable to open socket");
    fputs($fp, "$method $path HTTP/1.1\r\n");
    fputs($fp, "Host: $host\r\n");
    fputs($fp, "Content-type: text/plain\r\n");
    if ($method == 'POST') fputs($fp, "Content-length: " . strlen($data) . "\r\n");
    fputs($fp, "Connection: close\r\n\r\n");
    if ($method == 'POST') fputs($fp, $data);
    while (!feof($fp)) $buf .= fgets($fp,128);
    fclose($fp);
    return $buf;
$command = '<?xml version="1.0" encoding="utf-8"?><YAMAHA_AV cmd="GET"><Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone></YAMAHA_AV>';
/*$command = '<?xml version="1.0" encoding="utf-8"?><YAMAHA_AV cmd="PUT"><Main_Zone><Power_Control><Power>Standby</Power></Power_Control></Main_Zone></YAMAHA_AV>';*/
$yamip = '192.168.0.35';
$test = send_to_host($yamip.':80/YamahaRemoteControl/ctrl','POST','/YamahaRemoteControl/ctrl',$command);
echo $test;
Any idea?
Cheers
Fri Jan 31, 2014 2:51 am
col offline
Looks like this plugin is dead :(
Fri Jan 31, 2014 9:10 am
RogueProeliator offline
Try contacting him on GitHub, from the sounds of it in other threads, he prefers that interface for tracking bugs and issues. I believe the link is in his original post.
Tue Apr 01, 2014 9:00 pm
amannone offline
I have a Yamaha RX-V473 and also got an error trying to use the plugin. I created a GitHub account and submitted the error (below) as an issue to the project.
Yamaha Rx Receiver Error   Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 852, in deviceUpdated
  File "plugin.py", line 42, in deviceStartComm
  File "plugin.py", line 59, in updateStatus
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'text'
Tue Jul 15, 2014 9:36 am
dgahagan offline
I can't for the life of me figure out how to change the input. I have the power working, but the saved settings (1-4) and the input selection don't show up anywhere.
Any help is appreciated.
Wed Jul 16, 2014 9:09 pm
BenX10 offline
I think the problem is that Chad wrote this plugin for Yamaha's RX-Vx900, most commands differ to the newer series like my RX-V775. So I took Chad's plugin, did a lot of research for the commands for the RX-Vx75 series, added (as Chad said) significantly more features and voilà my RX-V775 is (nearly, zone 2 isn't implemented) completely controllable by Indigo. I sent him my version of his plugin and asked him to take a look and for permission - as its based on his work initially - to share it with the Indigo community.
I've received one reply: He wasn't sure if it would make sense to make one plugin for all IP controllable Yamaha's since RX-Vx900 or to make a separate one for every series (in case there are that big differences like Vx900 and Vx75). And he'll let me know when he has had more time to look at it. That was in mid of April, since then I've heard nothing from him.
Cheers,
Ben
Mon Jul 21, 2014 7:27 pm
Bleasel offline
I note that Chad has posted his plugin on Github (collaborative open source site)
https://github.com/discgolfer1138/indig ... x/branches
There are 2 branches with modifications.
Ben, perhaps you could create a third branch, and post your modifications there. This gives recognition to Chad as the originator of the plugin.
Thanks in advance.
Tue Jul 22, 2014 10:23 am
BenX10 offline
Oh, the second branch labeled "bernd-blazynski" is my version. So Chad has already reacted, this wasn't aware to me. That version should work with all RX-Vx75 models.
Cheers,
Ben
Thu Jul 24, 2014 3:09 pm
Bleasel offline
Ben
Many thanks for your version which I have been using for a few months.
It has enabled me to use a trigger to turn on the receiver and set the correct scene when Sonos is playing. Many thanks, my Sonos is now wife friendly again.
I have a Yamaha RX-A1010. Whilst the actions work, I am not able to read the state of the Yamaha. There is an error in the Event log.
Starting plugin "Yamaha RX-A1010 Receiver 0.1.2" (pid 8506)
Started plugin "Yamaha RX-A1010 Receiver 0.1.2"
Yamaha RX-A1010 Receiver Debug startup called
Yamaha RX-A1010 Receiver Error exception in deviceStartComm(Yamaha RX-A1010): 'NoneType' object has no attribute 'text'
I have found the specifications for the A1010:
http://www.google.com.au/url?sa=t&rct=j ... 8758,d.c2E
and I am trying to learn python, but at this stage I have not worked out what to change to load the states.
I would be most grateful for any assistance in correcting this.
Fri Sep 25, 2015 11:42 am
Betacruxis offline
Hello Guys.
Anyone has a working version of the plugin?
I downloaded the last version, installed it, but I've got this message:
2015-09-24 15:25:14.464 Yamaha Rx Receiver Debug updating status...
2015-09-24 15:25:14.789 Yamaha Rx Receiver Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 855, in deviceUpdated
So, I investigated a little further in the plugin website and made the latest suggested mods, but I keep having his error:
Enabling plugin "Yamaha Rx Receiver 0.1.1"
Starting plugin "Yamaha Rx Receiver 0.1.1" (pid 29620)
Started plugin "Yamaha Rx Receiver 0.1.1"
Yamaha Rx Receiver Debug startup called
Yamaha Rx Receiver Error exception in deviceStartComm(Living Home Theatre): 'NoneType' object has no attribute 'text'
Any help will be appreciated.
Thanks in advance.
Fri Sep 25, 2015 2:26 pm
colinpartridge offline
For what its worth I am using the cynical network plugin to communicate with a Yamaha RX-V575, I did try the RX plugin ( not the branch version ) with no luck some time ago. Granted I'm only using it to switch inputs and change volume etc but it works pretty well. Happy to help if I can
Colin
Fri Sep 25, 2015 2:50 pm
I haven't looked at the plugin, but my guess is that it's parsing XML data that it receives from the AVR. My next guess is that the plugin is looking for an XML key that's not in the XML--effectively saying that it wants to get the value of something located in KEY.text. Since KEY.text doesn't exist (or has a null value and thus, no text) it gets angry. If you can figure out which KEY is the culprit, you can wrap it in a try/except block (psuedo code):
    foo = KEY.text
except:
    foo = u"Key does not exist."
Hope this helps,
Dave
Sat Sep 26, 2015 8:06 pm
BenX10 offline
Betacruxis:
What model of receiver do you want to use with the plugin?
And DaveL17 is right with his guess, that's exactly what I've seen while making the changes from 0.1.1 to 0.1.2 for my RX-V775: This error message always occurred while the plugin tried to get values which doesn't exist (was a kind of try and error that time as I didn't had a clear documentation for my Yamaha model).
Cheers,
Ben
