Thanks Marty,
What model TV do you have? Also, which version of the iOS Samsung App works for you? v1.0 or 2.0?
Pete
MortenB wrote:Is it av way to specify which HDMI it shall change to? I found the command for HDMI but then I cannot specify if it is HDIM1, 2 or 3 that is going to be enabled.
haavarda wrote:Hi,
I am working on a setup where I display my security cameras as picture in picture (pip). I see that the original scripts support these commands. Would it be possible for you to add these commands?
KEY_PIP_ONOFF
I am not sure if it will work, but it would be an elegant way to activate PIP.
Håvard
howartp wrote:Hi Pete.
Do you know if the Kodi/CEC thing needs Raspberry PI, or if it will run on any Kodi hardware (PC, Mac?)
I'm wondering about moving my MacMini into the lounge where my TV is - it is headless anyway at the moment - and run Kodi on it.
(I'm assuming Kodi runs on PC and Mac - the website is down at the moment)
Peter
Redrocker wrote:Is this plugin still being supported? I have some interest in an additional function/button press. The remote that came with my Samsung Smart TV has a Voice button that I would like to see added.
This is how I see using this function: I recently added an Amazon Echo to my HA hardware devices, and would like to use Alexa to trigger the Voice button on the Samsung TV, which in turn would allow handoff of the voice commands to the TV. The thought here is that Alexa would not need to handle the umpteen commands to control the TV.
Thank you,
Mark
Comgen wrote:Thank you for contributing and developing a plug in.
Will you be developing for newer samsung TV's
