database location in python?
Fri Apr 03, 2020 12:38 pm
dduff617 offline
I have few testing/diagnostic scripts that reach into the Indigo log database and run some queries against it.
I was curious if there exists any way to reference the current database file other than by a specific hardcoded pathname in the script? I find that my scripts break with each point release of Indigo.
Or at least is the there a recommended way in a python script I can reference the "root" Indigo directory (/Library/Application\ Support/Perceptive\ Automation/Indigo\ <major version>.<minor version>/)?
Fri Apr 03, 2020 2:16 pm
Re: database location in python?
I believe you want:
indigo.server.getDbFilePath()
Also available:
indigo.server.getInstallFolderPath()
Lastly, check out this wiki page.
Fri Apr 03, 2020 2:25 pm
dduff617 offline
Thanks, Matt - that's very useful.
I should have been clearer but i was asking in the context of a discussion of SQL logger, so I was actually referring to the db file used by SQL logger (so I can write python code to query the database) - in my case using sqlite3.
I see that database you are referring to is the main Indigo database file. Still, I can get what I need using:
dbfile = indigo.server.getInstallFolderPath() + '/Logs/indigo_history.sqlite'
Fri Apr 03, 2020 2:36 pm
Yeah, I'd recommend getting the root install path and appending on the path to the default SQL file like that. The filename might be different if the user overrides the default, but for personal use your technique will be robust and not break with future Indigo upgrades.
