Started getting loads of SQL Logger errors
Sun Sep 08, 2019 2:10 pm
Re: Started getting loads of SQL Logger errors
this seems to do the trick: stop indigo (server and client) wait x secs; relaunch indigo server then client
put this into an "action group/ server/ execute script"
import os
# script to stop and relauch indigo w a wait fo 30 seconds... usefull if you have an postgres resync issue.
# replace your userid home dir and indigo V#  min 7.3
# OSX does not offer to print msecs in bash, set to 000 to keep indigo format
indigoV       = "7.3"
logFile       = "/Library/Application Support/Perceptive Automation/Indigo "+ indigoV +"/Logs/indigo_log.txt"
home          = "/users/karlwachs"
waitBfRelaunch  = "30" # seconds
cmd =  "#!/bin/bash\n"
cmd +=  "export HOME="+home+"\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 =========================================='                    >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 stop and relaunch indogo after "+ waitBfRelaunch +" seconds '  >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    stop indigo app '                              >> '"+logFile+"'\n"
cmd +=  "/usr/bin/osascript -e 'quit app \"Indigo "+indigoV+"\"'                                     >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    sleep 1 '                                      >> '"+logFile+"'\n"
cmd += "/bin/sleep 1\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    stop indogo server'                            >> '"+logFile+"'\n"
cmd += "/usr/local/indigo/indigo-stop        >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    sleep "+ waitBfRelaunch +"'                    >> '"+logFile+"'\n"
cmd += "/bin/sleep "+ waitBfRelaunch +"\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    start indigo server'                           >> '"+logFile+"'\n"
cmd += "/usr/local/indigo/indigo-start                                                               >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    sleep 3'                                       >> '"+logFile+"'\n"
cmd += "/bin/sleep 3\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    start indigo app'                              >> '"+logFile+"'\n"
cmd += "/usr/bin/open '/Applications/Indigo "+indigoV+".app'                                         >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ==relaunch==    done'                                          >> '"+logFile+"'\n"
cmd +=  "date '+%Y-%m-%d %H:%M:%S.000 ========================================='                     >> '"+logFile+"'\n"
f=open("/tmp/restartIndigo.sh","w")
f.write(cmd)
f.close()
indigo.server.log("/tmp/restartIndigo.sh &  --> \n"+cmd )
os.system("chmod +x /tmp/restartIndigo.sh")
os.system("/tmp/restartIndigo.sh &")
Sun Sep 08, 2019 2:48 pm
Busta999 offline
jay (support) wrote:
Busta999 wrote:
I am/was running Postgres :-)
Did you try to repair the Postgres db? I think there are tools out there...
No I did not.
All the historical data I am using is in the CSV files crated by MatPlotLib.
Is there anything else I am missing? Because it is just running fine once I created a new one.
Thu Oct 17, 2019 4:18 am
Busta999 offline
Ok
Following an orderly restart of the Mac mini - the SQL DB was corrupted again.
Incrementing the DB name by 1 forced it all to be recreated.
Despite Indigo not reporting any issues when closing down it appears that shutting down Indigo as part of reboot is causing the SQL DB to corrupt.
Next time I reboot (only a few of times a year) I will ensure that Indigo is shutdown before starting a reboot and see if the issue repeats.
This is the second SQL DB corruption I have encountered in a couple of months - both during an orderly reboot.
