SQL Log Entries
Posted: Sat Nov 04, 2017 2:35 am
Need some help here with my log being inundated with SQL entries. See example below, this seems to have started when my Mac Mini restarted by itself - not sure why. Below is just a snapshot, I've actually had to disable it for the moment.
Any suggestions on solving would be greatly appreciated.
- Code: Select all
SQL Logger updating all device tables
SQL Logger Error exception trying to create table device_history_1423602820 ("003 - Binary Sensor")
SQL Logger Error database disk image is malformed
SQL Logger Error exception trying to insert row into table device_history_1423602820 ("003 - Binary Sensor")
SQL Logger Error INSERT INTO device_history_1423602820 ("onoffstate") VALUES (%s);
SQL Logger Error exception trying to create table device_history_1015521582 ("003 - Binary Sensor 2")
SQL Logger Error exception trying to insert row into table device_history_1015521582 ("003 - Binary Sensor 2")
SQL Logger Error INSERT INTO device_history_1015521582 ("onoffstate") VALUES (%s);
SQL Logger Error exception trying to create table device_history_1916264067 ("003 - Temperature")
SQL Logger Error exception trying to insert row into table device_history_1916264067 ("003 - Temperature")
SQL Logger Error INSERT INTO device_history_1916264067 ("accumenergytimedelta", "accumenergytotal", "curenergylevel", "sensorvalue", "sensorvalue_ui") VALUES (%s, %s, %s, %s, %s);
SQL Logger Error exception trying to create table device_history_600073177 ("014 - Temperature")
SQL Logger Error exception trying to insert row into table device_history_600073177 ("014 - Temperature")
SQL Logger Error INSERT INTO device_history_600073177 ("accumenergytimedelta", "accumenergytimedelta_ui", "accumenergytotal", "accumenergytotal_ui", "curenergylevel", "sensorvalue", "sensorvalue_ui") VALUES (%s, %s, %s, %s, %s, %s, %s);
SQL Logger Error exception trying to create table device_history_1623834288 ("015 - Relay Switch 2")
SQL Logger Error exception trying to insert row into table device_history_1623834288 ("015 - Relay Switch 2")
SQL Logger Error INSERT INTO device_history_1623834288 ("accumenergytimedelta", "accumenergytimedelta_ui", "accumenergytotal", "accumenergytotal_ui", "curenergylevel", "curenergylevel_ui", "onoffstate") VALUES (%s, %s, %s, %s, %s, %s, %s);
SQL Logger Error exception trying to create table device_history_1084713715 ("015 - Temperature")
SQL Logger Error exception trying to insert row into table device_history_1084713715 ("015 - Temperature")
SQL Logger Error INSERT INTO device_history_1084713715 ("accumenergytimedelta", "accumenergytimedelta_ui", "accumenergytotal", "curenergylevel", "curenergylevel_ui", "sensorvalue", "sensorvalue_ui") VALUES (%s, %s, %s, %s, %s, %s, %s);
SQL Logger Error exception trying to create table device_history_1365258102 ("019 - Input 2")
SQL Logger Error exception trying to insert row into table device_history_1365258102 ("019 - Input 2")
SQL Logger Error INSERT INTO device_history_1365258102 ("onoffstate") VALUES (%s);
SQL Logger Error exception trying to create table device_history_1903043483 ("019 - Input 3")
SQL Logger Error exception trying to insert row into table device_history_1903043483 ("019 - Input 3")
SQL Logger Error INSERT INTO device_history_1903043483 ("onoffstate") VALUES (%s);
SQL Logger Error exception trying to create table device_history_1240977495 ("019 - Temperature")
SQL Logger Error exception trying to insert row into table device_history_1240977495 ("019 - Temperature")
