sqlite file location format
Thu Oct 12, 2017 4:20 pm
siclark offline
I have got my sql logger config in a mess and it managed to blank out the sqlite file location, and now I get these errors
SQL Logger Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
SQL Logger Error Error in plugin execution UiClosed1:
File "plugin.py", line 645, in closedPrefsConfigUi
File "plugin.py", line 473, in _connectToSqlDb
ValueError: invalid literal for int() with base 10: ''
Is this related? I have even removed the sql lite file and as its not creating a new version, I'm sure the various combinations I am using in there are wrong.
What should it be?
Fri Oct 13, 2017 8:49 am
siclark offline
Re: sqlite file location format
I get the same thing with trying to use new postgres setup or SQLite with or without an existing file.
Is there an issue in my indigo setup rather than the db file?
How do I force indigo to create a new SQLite file?
Fri Oct 13, 2017 9:06 am
Shutdown indigo server
Delete SQLite file
Restart indigo server
Should reset the SQLite environment
Fri Oct 13, 2017 11:54 am
siclark offline
Cheers but Still get same error message. This happens whether or not I have an SQLite file or whether it's SQLite or postgres.
Fri Oct 13, 2017 3:56 pm
