Unable to Configure SQL Logger after upgrade to Yosemite
Thu Sep 22, 2016 10:26 am
colinpartridge offline
I have just upgraded my Indigo Server (6.1.10) Mac up to Yosemite. All appears to have gone well so far except for SQL logger. I get the following error in the Log when I try to access the Plugin configuration.
Error (client)                  timeout waiting for plugin response from com.perceptiveautomation.indigoplugin.sql-logger for request UiGetValues1
  Error (client)                  timeout waiting for plugin response from com.perceptiveautomation.indigoplugin.sql-logger for request CallPluginFunc
  Error (client)                  runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Any thoughts?
Colin
Thu Sep 22, 2016 10:43 am
Re: Unable to Configure SQL Logger after upgrade to Yosemit
Disable all 3rd party plugins and try again.
Thu Sep 22, 2016 10:55 am
Hi Jay
I have tried what you suggested with the same result.
Colin
Thu Sep 22, 2016 11:13 am
I've just looked at Activity monitor and it appears that the SQL logger plugin is hanging ( not responding).
/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/SQL Logger.indigoPlugin/Contents/Server Plugin
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost
/System/Library/Frameworks/Python.framework/Versions/2.6/Python
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/GraphiteDarkAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/AccessibilityDarkGraphiteAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/AccessibilityVibrantLightAppearance.car
/private/var/folders/n0/fttybfg94fd944dn7fjv512w0000gv/C/com.apple.scriptmanager2.le.cache
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/cStringIO.so
/usr/share/icu/icudt53l.dat
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/GraphiteAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/VibrantLightAppearance.car
/System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/SystemAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/AccessibilityAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/AccessibilityGraphiteAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/DarkAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/AccessibilityDarkAppearance.car
/System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/AppleKeyboardLayouts-L.dat
/System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/datetime.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/time.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/strop.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_functools.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_collections.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/operator.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_socket.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_ssl.so
/usr/lib/libssl.0.9.8.dylib
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/cPickle.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_struct.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/select.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/readline.so
/usr/lib/libedit.3.dylib
/usr/lib/libncurses.5.4.dylib
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/fcntl.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/termios.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_fileio.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_bytesio.so
/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/SQL Logger.indigoPlugin/Contents/Server Plugin/plugin.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/bz2.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/binascii.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_sqlite3.so
/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/pyexpat.so
/usr/lib/libexpat.1.dylib
/usr/lib/dyld
/private/var/db/dyld/dyld_shared_cache_i386
/dev/null
/dev/null
/dev/null
count=2, state=0x2
localhost:62381->localhost:indigo-server
->0xfab6558560cfa29
->0xfab655856904109
/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite
Thu Sep 22, 2016 4:12 pm
How do you know the plugin is hanging?
Try shutting down the server, removing the sqlite file (last line of whatever you pasted above) then restarting.
Sat Sep 24, 2016 4:55 am
Re: Unable to Configure SQL Logger after OS upgrade (Fixed)
SQL logger now appears to be working as expected, but I couldn't tell you why.
C
