compress SQLITE in place
Tue Jun 21, 2016 7:27 pm
is there a way to compress the SQLITE3 database while indigo is running?
I am at 45+ GBYTE now and things are getting slow (Sql plugin takes 15 minutes to finish at startup)
Old data has been pruned, but the size has not changed, as expected. Can I do a "vacuum" command while indigo is running?
Or I could do a database dump and rebuild, but that will take many hours, but I would like like to loose several hours of data.
thanks
Tue Jun 21, 2016 8:27 pm
Re: compress SQLITE in place
According to this website:
The VACUUM command cleans the main database by copying its contents to a temporary database file and reloading the original database file from the copy.
[SNIP]
The VACUUM command will fail if there is an active transaction.
So sounds like it has to be shut down. I suspect you could start a new db and let it run while you're compressing the old one. Then merge the old one back in to the new one.
If you really need a lot of historical data, I'd recommend that you de-normalize the transactional data in the logger db into something more optimized for the kinds of data mining you want to do.
Alternatively, switch to PostgreSQL which is likely to do much better with larger data sets, and probably has better tools for truncating tables once you're done with the data.
