Page 2 of 2
Re: [ANSWERED]: SQL Logger error
PostPosted: Thu Jul 23, 2015 9:27 am
by jens
Any solotion. for it??
Sent from my iPhone 6 using Tapatalk
PostPosted: Thu Jul 23, 2015 10:08 am
by matt (support)
You said that the client and maybe server were on when you deleted the file. DId you ever try doing it again as instructed with both the client and server stopped first (before deleting the file)?
PostPosted: Fri Jul 24, 2015 10:57 am
by jens
SQL log file is no more there...
and it still says it can not open the file ??
PostPosted: Fri Jul 24, 2015 11:37 am
by matt (support)
Please copy/paste the Event Log results showing the errors (even if they are the same errors). The more info we have here, the better we can troubleshoot the problem.
PostPosted: Fri Jul 24, 2015 11:52 am
by jens
Here is the log
PostPosted: Fri Jul 24, 2015 12:03 pm
by matt (support)
You have changed the default file path for the database file to one that has the wrong folder name (Perceptive auto versus Perceptive Automation). Open the SQL Logger plugin's config UI and copy/paste this in for the path:
/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite
PostPosted: Fri Jul 24, 2015 12:32 pm
by jens
Thank you so much Matt, now it works again...
:D :D
