SQL Logger poll
How do you use the SQL Logger plugin?
4
10
3
12
Sun Jun 05, 2022 3:16 am
Turribeach offline
Re: SQL Logger poll
Just found this post which says v14 is not supported due to protocal changes and incompatibility with the library Indigo uses. Is this still the case? Thanks
Sun Jun 05, 2022 8:29 am
RogueProeliator offline
Re: SQL Logger poll
I have the SQL Logger about 90% of the way upgraded to Python 3 and a new library which should support that... need to carve out a bit time to get that over the finish line with the one or two remaining issues.
Fri Feb 24, 2023 10:46 am
Different Computers offline
Re: SQL Logger poll
Seems like this isn't working in v.2022.2
The last captured statuses are from when I shut down 2022.1
Fri Feb 24, 2023 3:43 pm
Re: SQL Logger poll
Check to make sure your SQL Logger configuration settings still look correct (Plugins->SQL Logger->Configure... menu item), and then reload the plugin (via menu item). Presuming it still doesn't work, copy/paste the Event Log window results showing what happens after the reload into a reply for us.
Fri Feb 24, 2023 4:37 pm
Re: SQL Logger poll
Haven't touched this plugin in years, so no idea what the correct config is.
But here's what mine looks like.
DB type: SQLite
SQLite file: indigo_history.sqlite
Device state history checked
Change states only NOT checked
The other options don't seem related, but I did turn on Show debug logging. Nothing's appearing in the Indigo log, but maybe that's not where it would show. Whoops! I reloaded the plugin and instantly saw huge debug messages showing up--but all green.
However, the variables still have the old messages from 2022.1
I also have two possibly related variables I don't recall creating "SQLLineOutput" and SQLValueOutput". both are empty.
OK, I'm starting to see what might be the issue. Looks like the web server logging for errors uses different syntax that no longer matches my search string. I'm changing that and we'll see if the trigger works. (it used to say "size too large" and now says "too large".
