[ANSWERED] Setting up the NOAA weather plugin
Mon May 18, 2015 9:48 pm
Radjin offline
I have the plugin enabled and the correct code entered to where it is showing the temperature in the device display. But I can see no other data nor do I have any additional variables with which to control schedules or triggers. I'm new to Indigo and so far have been pretty good at getting the 120 or so devices all coordinated but this particular plugin has so far evaded my comprehension.
How do I create variables from the weather data or use it to modify a schedule or activate a trigger?
Thanks in advance
Radjin~
Tue May 19, 2015 4:13 am
Re: Setting up the NOAA weather plugin
Hi Radjin - Welcome to Indigo.
What you are looking for are "Custom Device States" which are common for devices that are created with plugins. In the main Indigo device window, towards the bottom, you have a "Device Details" box. Your custom device states are right below that, only you can't see them due to the fact that the OS X scroll bar is most likely hidden from you. You can either "grab" the small circle and drag that portion of the window higher, or scroll in that area to expose the custom states. Here's a picture to demonstrate.
Screen Shot 2015-05-19 at 5.11.21 AM.png (29.28 KiB) Viewed 3454 times
Cheers,
Dave
Tue May 19, 2015 6:58 am
Radjin offline
And there it is; the all light gray colors totally hid the scroll bar. Thank you. :mrgreen:
To extend my question, how do I use this information to control a schedule, trigger or create a variable? The NOAA plugin page gets you to the install but goes no further on how to use the plugin.
Radjin~
Tue May 19, 2015 7:11 am
For control pages, you want to add a new device, then select your weather device, then select from the many values:
Screen Shot 2015-05-19 at 8.08.44 AM.png (39.67 KiB) Viewed 3439 times
For Triggers, you want to add a new device, then select a trigger (for example, a device state changes), and pick the device state to trigger on.
Screen Shot 2015-05-19 at 8.10.29 AM.png (65.54 KiB) Viewed 3439 times
Dave
Tue May 19, 2015 7:02 pm
Radjin offline
Re: Setting up the NOAA weather plugin (ANSWERED)
Brillent, thanks again. I was looking to add as a condition to affect a schedule (ie my irrigation control), to stop it from running if it is raining and although your reply did not point to it directly it gave me the information I needed.
Very much appreciated.
PS can this be added as a variable as well?
Radjin~
Tue May 19, 2015 7:14 pm
I'm not exactly sure what you're looking for.
Do you want to add a value to a variable or do you want to use a variable as a condition?
Dave
Tue May 19, 2015 7:27 pm
Radjin offline
I am looking to add a condition, as a variable. I think I have it figured out how to use as a condition or trigger.
Radjin~
Tue May 19, 2015 7:36 pm
I tried that. The issue is that the conditions at NOAA are only updated every 2 hours. So if you have light rain its light rain for 2 hours. Or no rain it is no rain for 2 hours (at least with my NOAA station) I even did a counter adding x amount depending on the rain conditions testing every 15 minutes:
light drizzle .. heavy down p. Incremented each by 1.3 . There are 10 different levels of rainfall 3 or 4 main words (drizzle, rain, shower, downpour ..) and each comes with qualifier: light normal heavy ..)
That way I could count the rainfall, but again the conditions only change every 2 hours..
and then there are thunderstorms and none of the "rain words" .. appear in the weather condition ..
here the python code I did some 18 months ago. and you will see that was one of my first py scripts.
import sys
## karl wachs
## V1.1
## Sept. 2 2013
## call every 15 minutes
## checks NOAAplus device information of currentcondition
## if  drizzle / rain  add to raincount multiply by 1/27 (mult1)
## if light / normal / heavy  multiply by 1/3/9  (mult2)
## rain constant for normal rain every 15 minutes is:  normal rain per hour is 0.205/2 inches
## total add = mult1*mult2*rainperunit
inchPerRainUnit = 0.205 / (4 * 81 * 2)   ## still tuning
rightNow = indigo.server.getTime()
theHour = int(rightNow.hour)
theMinute = int(rightNow.minute)
rainCount = indigo.variables[1943077276]
rainCountString = str(rainCount.value)
rainCountNumber = float(rainCountString)
## NoaaCondition = indigo.variables[1262360358] # "NOA_loveField_condition"
noaadevice = indigo.devices[120648462] # "NoaPlusLoveField"
currentCondition = noaadevice.states['currentCondition']
Noaa = currentCondition.upper()
updateYesterday = 'no'
if theHour < 1 :    ## it is now tomorrow, move raincount to yesterday variable
    if theMinute < 15 :
        rainCountYesterday = rainCountString
        rainCountNumber = float(0)
        rainCountString = '0'
        updateYesterday ='yes'
## check what condition, if rain drizzel ligh heavy string is present
rainYN  = int(Noaa.find('RAIN'))
drizzleYN  = Noaa.find('DRIZZLE')
lightYN  = Noaa.find('LIGHT')
heavyYN  = Noaa.find('HEAVY')
mult1 = 0
if rainYN  > -1 :
    mult1 = 27
if drizzleYN  > -1 :
    mult1 = 3
mult2 = 3
if lightYN  > -1 :
    mult2 = 1
if heavyYN  > -1 :
    mult2 = 9
rainToAdd = mult1 * mult2 * inchPerRainUnit
rainCountString = str(rainCountNumber + rainToAdd)
indigo.variable.updateValue(1943077276,rainCountString)
if updateYesterday =='yes':
    indigo.variable.updateValue(11503249,rainCountYesterday)
Tue May 19, 2015 7:53 pm
Radjin~
If you mean setting a variable based on certain conditions, sure. That's a very common usage of variables.
Under "Actions", select "Variable Actions".
Tue May 19, 2015 10:03 pm
Radjin offline
[/code]
Well, that's disapointing but expected. Then I will rely on a moister sensor I placed in a downspout some time ago as a rain monitor test that worked quite well. However all the above was still very informative as I learned how to set variables and update them, and how to access the NOAA data, all thanks to your help.
Fri May 29, 2015 11:05 pm
Radjin offline
[/code]
I was perusing your code and it suddenly hit me to try and see what condition I could define. Turns out that I can select "if NOAA currentConditions includes the word rain" fog, ice, snow. I told the conditions in Indigo that if those words were included in the currentConditions then do not run the schedule. Theoretically that should defer a schedule run when it is not necessary. It's summer here now so will have to wait to test.
Radjin~
