iTunes Playlist in Indigo 7
Tue Aug 29, 2017 5:12 pm
Monstergerm offline
The iTunes plugin on both of my Indigo iTunes servers is not populating the Playlist field for any of my regular or smart playlists. I am pretty sure this worked before under Indigo 6. Any thoughts?
Wed Aug 30, 2017 9:21 am
marketability offline
Re: iTunes Playlist in Indigo 7
same here but I'm pretty certain it happened after an iTunes upgrade rather than when I moved to Indigo7
Wed Aug 30, 2017 10:54 am
Yeah, it's likely due to an iTunes change since we haven't changed that plugin in many years. I'll look into it.
Wed Aug 30, 2017 12:22 pm
Different Computers offline
Could you share the version of iTunes you're using, so I can know what not to upgrade to?
Alternately, if I'm already there we know it's not a version problem because mine is working.
Wed Aug 30, 2017 12:39 pm
Monstergerm offline
I have problems with iTunes 12.6.2.20.
I tested the iTunes plugin that came with Indigo 6 and it has the same problem with Playlist not getting populated. So it must be iTunes related.
Wed Aug 30, 2017 12:45 pm
Yep, that version isn't working for me either. Looking into it now.
Wed Aug 30, 2017 1:21 pm
12.6.2.20 for me too
not 100% sure but think it worked with the previous version
Wed Aug 30, 2017 1:24 pm
So, iTunes is now returning 0 (zero) for the ID of the playlist that's currently playing. Regardless of the playlist. So this is either a bug or a change in their internal API. That API isn't published so it has to be reverse engineered (and not by me!). So, unfortunately, there's really not much I can do about it until either Apple fixes it (if it's a bug) or until someone figures out what they changed and how to deal with it. I've looked at the very few open source projects that do iTunes control and none seem to have addressed it yet.
Wed Aug 30, 2017 1:55 pm
just out of interest, the playlist ID and name are accessible via applescript (teaching grandmother to suck eggs - apologies)
as a hack around a trigger on track change that runs...
tell application "iTunes"
   set thePlaylist to name of current playlist
   set thePlaylistID to id of current playlist
end tell
set value of variable "testplay" to thePlaylistID
at least allows me to display the playlist on my control pages
Wed Aug 30, 2017 4:04 pm
The mystery deepens:
12.6.2.20 is working fine for me. Status reported in Indigo, Indigo control page elements (that use the iTunes device, not tied to AppleScripts) are working fine.
Wed Aug 30, 2017 7:58 pm
It's updating the playlist custom state? Everything else seems to be fine, it's just that the current playlist name state isn't getting updated. If that is working, what OS version are you using on the Mac running iTunes?
Wed Aug 30, 2017 10:33 pm
RogueProeliator offline
12.6.2.20 on OS X 10.11.6 is not working for me... :-(
Thu Aug 31, 2017 12:29 am
Korey offline
Same deal here, everything seems to still be working but the playlist state does not change. :roll:
Apple & iTunes sux, just another push to move me fully to Spotify, now how about a Plugin?
iTunes 12.6.2.20
Indigo 7.0.3
OSX 10.10.5
Korey
Thu Aug 31, 2017 7:01 am
I'm running 10.11.x (6 I think.)
Here's the funny thing--I never report out the playlist name. I report out the track, its rating, but never its playlist.
Playlist selection from a STATIC subset of them still works though.
Thu Aug 31, 2017 8:54 am
You can see the value in the Custom States list, below the Device Details tile when you select the device in the device list in the Mac client:
