[ANSWERED]: Start iTunes?
Sat Jan 17, 2015 4:54 am
Stoutjesdijk offline
Hello,
If I understand correctly, iTunes needs to be running to use this plugin. Is it possible to use the plugin even if iTunes is NOT running (i.e., it will first start the program, then execute the trigger)?
Best regards
Mark
Best regards,
Mark
Trying to tie it all together...
| Indigo 7.5 | Plex | NAD M33 | LG | Panasonic | GlobalCaché GC100 | Sonos | Nest |
Sat Jan 17, 2015 11:34 am
Re: Start iTunes?
Hi Mark,
The plugin won't do it, but you can use this AppleScript line to launch it:
launch application "iTunes"
Mon Jan 19, 2015 12:34 pm
jltnol offline
Re: [ANSWERED]: Start iTunes?
And if the copy of iTunes you want to launch is on a different computer than the one running Indigo, this Apple script should work..
set theRemoteMac to "eppc://username:passowrd@computer-name.local"
tell application "Finder" of machine theRemoteMac
open ("/Applications/iTunes.app" as POSIX file as alias)
end tell
Just change username, password and computer name as needed....
