[SOLVED]iTunes Pause and Speak script
Fri Dec 26, 2014 6:32 pm
achterberg offline
I have a trigger action that updates variables at a device state change (on a temperature change), one of them named alertDesc. The script below should check the value of alertDesc and if "None" (currently hard-coded into the variable) abort the script. The idea being that if it gets populated with real data, the script should run, and the alertDesc variable is updated with "None" to prevent execution every time the trigger is fired. But it runs at every trigger action. It is being called as an external python script, to prevent the embedded timeout issue, at the end of the trigger action populating the variables. Is there a better way of doing this?
if itunesPlugin.isEnabled():
    alertDesc = indigo.variables[8234576]
    if alertDesc.value == "None":
         return
         spokenString = "Alert %s  Expires %s." % (alertDesc.value, alertExpire.value)
         itunesPlugin.executeAction("pauseAndSay", deviceId=88947230, props={'message':spokenString})
indigo.variable.updateValue(alertDesc, "None")
alertDesc.refreshFromServer()
Sat Dec 27, 2014 9:28 am
Re: iTunes Pause and Speak script
I'm not sure what is going wrong. Try putting some debug logging into the script, such as:
indigo.log("alertDesc.value is %s" % alertDesc.value)
to see if you can deduce exactly what is occurring.
Sat Dec 27, 2014 8:53 pm
Are you sure you're inserting the word "None" rather than just setting it to the empty string?
Sat Dec 27, 2014 10:24 pm
achterberg offline
Yes, the word "None", I know it's confusing; I used other terms thinking almost the same thing. The only way this works (so far), is to check the value of alertDesc (in an embedded python script that is tacked on to the end of a trigger action) against the variable value. That script calls an action group that calls an external .py script which does the speaking part if the check fails. I will probably end up deleting the action group call if this continues to work.
Running the entire script as an external .py script fails. It doesn't even find the alertDesc.value part in the logging test suggested by Matt. (I think he also meant indigo.server.log in his message).
I'm posting another question in the wunderground plugin forum later with another idea.
Sun Dec 28, 2014 11:38 am
achterberg offline
I have abandoned the variable route and am keying off of values in the plugin, thanks to assistance from another post.
This compiles but doesn't return:
pluginId = "com.fogbert.indigoplugin.wunderground"
plugin = indigo.server.getPlugin(pluginId)
if plugin.isEnabled():
   dev = indigo.devices[540318992]
   idS = dev.states["alertStatus"]
   if idS == 'false': # or "false", 'False', "False"
        return
   # if dev.states["alertStatus"] == 'false':    # obviously, this doesn't work either
      # return
      execfile('/Library/Python/2.5/site-packages/Alert1.py')
This return works:
    idS = str(int(dev.states["alertStatus"]))
    if idS == "0":    # executes file Alert1.py if hardcoded as 1
        return
[/code]
Sun Dec 28, 2014 5:02 pm
achterberg offline
Received a freeze alert and the script seems to work with a real world "true". I'm still not sure why it didn't (doesn't) return with "false". For the Error "speak string too long" is that an Indigo limitation; if so, for reference, what is the limit? I deleted the speak message substitution, not important for this exercise anyway.
Mon Dec 29, 2014 12:33 pm
Sorry, not following you at all on this one. Can you clarify what you're seeing and what's not working (it doesn't seem to relate to your earlier post)?
Mon Dec 29, 2014 1:50 pm
achterberg offline
Sorry, it does kind of ramble doesn't it, it made sense to me when I sent it. I'll do a list:
1. Received a freeze alert and the script seems to work with a real world "true". (this is good!)
2. I'm still not sure why it didn't (doesn't) return with "false". (I'm waiting until the alerts expire and the plugin returns "false" to check this again)
3. In the Alert1.py file that is called by the trigger (code in previous message), I was keying to the alertMessage1 value in the plugin that sets a variable for pauseandsay to speak. Doing this creates an error "speak string too long" in the log file, because the value of alertMessage1 is too long. Deleted the message variable because it wasn't necessary anyway and the script works fine (no error). It is not a matter of it not working; it seems to be doing what it should. I was just curious, for reference, what the limitation is in Indigo (or whatever is causing the error message) to cause/not cause an error of "speak string too long"?
I'll add 4. This is a proof of concept and a learning python exercise (trying to convert all applescripts to python to the extent possible); this will probably be modified for other things besides getting the weather alerts every time the temperature changes. So #2 above is a mystery (probably some coding error on my part), #3 is a curious question, and other than an erroneous date (which is not the plugin or Indigo, just bad data apparently), all is good.
Mon Dec 29, 2014 4:11 pm
Can't answer #2 - that's dependent on what the plugin inserts for the state value.
I don't recall off the top of my head what the text limit is on spoken text. Can you copy/paste the exact line from the event log? I don't recall anyone hitting the limit before... ;)
Mon Dec 29, 2014 4:52 pm
achterberg offline
The original one is long gone in another log file so I made a fresh one for you:
  Error                           speak string too long
text is red, of course.
Mon Dec 29, 2014 7:41 pm
The limitation on the number of letters that can be spoken (which was 512) has been removed. That change will be in Indigo 6.0.19.
Mon Dec 29, 2014 8:09 pm
achterberg offline
Great, thanks.
Sent using Tapatalk
Wed Dec 31, 2014 5:15 pm
achterberg offline
Just for anyone's future reference:
   dev = indigo.devices[540123992]
   # if dev.states["alertStatus"] == 'false':    # python can't compare different types, in this case a boolean and string
    if not dev.states["alertStatus"]:    # this works
        return
Wed Dec 31, 2014 6:28 pm
In Python, you use the word False to represent the boolean (no quotes) - so this would work as well:
if dev.states["alertStatus"] == False:
Wed Dec 31, 2014 6:44 pm
Thanks Jay.
Right now, the state ['alertStatus'] is value type string. This is something that I plan to address before taking the plugin out of beta status.
Dave
