Genie: all commands give error code 400
Sat Oct 01, 2016 7:26 am
dlleon offline
I'm running the latest version of Indigo w/ a genie. All commands sent to the Genie give a variation of this error:
DIRECTV DVR Control Error Send key press action failed with status code: 400 message: Bad Request.Exception=null (probably an incorrect key name: 'active')
DIRECTV DVR Control Error Send key press action failed with status code: 400 message: Bad Request.Exception=null (probably an incorrect key name: '5')
Any ideas on what I'm doing wrong? the only think I can think of is that the indigo server has multiple IP addresses, maybe it's looking at the wrong client mac address?
Sun Oct 02, 2016 9:20 am
Re: Genie: all commands give error code 400
That routing issue may be the problem. Disable the network interface that's not on the same network as your directv and see if that makes any difference,
