Page 1 of 2
Ideas on why I can't edit DirecTV actions?
Posted:
Sat Oct 25, 2014 12:10 pm
by ChopOMatic
The screencast linked below is the best way to understand what I'm seeing, but in a nutshell, when I click to EDIT ACTION SETTINGS for a DirecTV plugin action, I get the WaitWheel for 15-30 seconds, and nothing more.http://www.screencast.com/t/xbs6otKJFfl
Re: Ideas on why I can't edit DirecTV actions?
Posted:
Sat Oct 25, 2014 2:36 pm
by DaveL17
One possibility is if the IP address of your DirecTV receiver has changed.
Have you tried to add a new action?
Posted:
Sat Oct 25, 2014 2:39 pm
by ChopOMatic
The IP addy is correct. (Permanently assigned IP via the router.)
Posted:
Sun Oct 26, 2014 7:37 pm
by jay (support)
The spinning beachball means that the indigo server is having difficulty talking to the plugin. That usually means you have some plugin that's misbehaving. I'd start by disabling any 3rd party plugins and see if it changes anything. You can then narrow down the offending plugin.
Posted:
Tue Oct 28, 2014 7:30 pm
by ChopOMatic
Thanks, Jay. I'll look into that.
BTW, has anyone tinkered with getting feedback from DirecTV receivers to display on control pages? I know it's possible because I have a remote control app called Roomie on my iPad that displays a ton of info from the receiver, like My Recordings, the program guide, rating and such for what's currently playing, etc.
Posted:
Tue Oct 28, 2014 8:02 pm
by jay (support)
I vaguely recall some status commands in the API, but my goal was really just control. I do have a feature request in place to look at adding status (some day).
Posted:
Sat Dec 20, 2014 8:18 pm
by DaveL17
Jay said: I vaguely recall some status commands in the API, but my goal was really just control. I do have a feature request in place to look at adding status (some day).
Taking a break from a plugin project and before I knew what happened, I had this hammered out. This code just logs information reported by the receiver; you'll have to convert the code to write the information to variables or what have you. The only other thing that needs to be adjusted is to enter the IP of the unit in question (DTVIP).
- Code: Select all
#! /usr/bin/env python2.5
# -*- coding: utf-8 -*-
import simplejson
import urllib2
DTVIP = "10.0.1.123"
url = "http://%s:8080/tv/getTuned?" % DTVIP
f = urllib2.urlopen(url)
simplejson_string = f.read()
f.close()
parsed_simplejson = simplejson.loads(simplejson_string)
##### Log the Response #####
indigo.server.log("Query: %s" % parsed_simplejson['status']['query'])
indigo.server.log("Response: %s" % parsed_simplejson['status']['msg'])
indigo.server.log("HTTP Status Code: %s" % parsed_simplejson['status']['code'])
indigo.server.log("Command Result: %s" % parsed_simplejson['status']['commandResult'])
indigo.server.log("Program Title: %s" % parsed_simplejson['title'])
indigo.server.log("Episode Title: %s" % parsed_simplejson['episodeTitle'])
indigo.server.log("Call Sign: %s" % parsed_simplejson['callsign'])
indigo.server.log("Major Channel: %s" % parsed_simplejson['major'])
indigo.server.log("Minor Channel: %s" % parsed_simplejson['minor'])
indigo.server.log("Program Rating: %s" % parsed_simplejson['rating'])
indigo.server.log("DirecTV Station ID: %s" % parsed_simplejson['stationId'])
indigo.server.log("DirecTV Program ID: %s" % parsed_simplejson['programId'])
indigo.server.log("Is Recording: %s" % parsed_simplejson['isRecording'])
indigo.server.log("Is VOD: %s" % parsed_simplejson['isVod'])
indigo.server.log("Start Time: %s" % parsed_simplejson['startTime'])
indigo.server.log("Offset: %s" % parsed_simplejson['offset'])
indigo.server.log("Duration: %s" % parsed_simplejson['duration'])
indigo.server.log("Is Off Air: %s" % parsed_simplejson['isOffAir'])
indigo.server.log("Is PC Locked: %s" % parsed_simplejson['isPclocked'])
Here is sample output:
- Code: Select all
Script Query: /tv/getTuned?
Script Response: OK.
Script HTTP Status Code: 200
Script Command Result: 0
Script Program Title: Blackhawks @ Blue Jackets
Script Episode Title: Chicago Blackhawks at Columbus Blue Jackets
Script Call Sign: WGN
Script Major Channel: 9
Script Minor Channel: 65535
Script Program Rating: No Rating
Script DirecTV Station ID: 3223469
Script DirecTV Program ID: 13697247
Script Is Recording: False
Script Is VOD: False
Script Start Time: 1419120000
Script Offset: 7718
Script Duration: 9000
Script Is Off Air: False
Script Is PC Locked: 3
This has been tested with an HR-34. There is other information that the query might return depending on what the receiver is doing (i.e., playing a recording, playing a music channel, etc.) This was watching live programming.
Cheers,
Dave
Posted:
Sun Dec 21, 2014 9:06 pm
by ChopOMatic
Thanks, Dave. Can't wait to check it out.
Posted:
Sun Dec 21, 2014 9:30 pm
by DaveL17
ChopOMatic wrote:Thanks, Dave. Can't wait to check it out.
Sure thing. Let me know if you have any questions.
Posted:
Mon Dec 22, 2014 4:53 pm
by ckeyes888
Looks very cool. Maybe post a bit of example code, for us Python challenged types, to write
a state to a variable?
Carl
Posted:
Mon Dec 22, 2014 6:06 pm
by DaveL17
Of course! Using the code above:
- Code: Select all
import simplejson
import urllib2
f.close()
programTitle = parsed_simplejson['title']
indigo.variable.updateValue(144522421, programTitle)
except:
indigo.variable.updateValue(144522421, " ")
Change the IP address to your receiver (DTVIP) and the variable ID number to one that matches yours. Just repeat the last 5 lines for each value that you want to use.
Dave
Posted:
Mon Dec 22, 2014 6:24 pm
by ckeyes888
Love it, works perfectly!
Thanks a bunch!
Carl
Posted:
Mon Dec 22, 2014 6:29 pm
by DaveL17
My pleasure.
Dave
Posted:
Mon Dec 22, 2014 8:01 pm
by ckeyes888
When adding a few more states I'm finding very few will work.
In particular ['major'] to get the channel number.
Have you seen that as well?
Carl
Posted:
Mon Dec 22, 2014 8:35 pm
by DaveL17
Hi Carl - what are you seeing? The field that seems to choke the most often for me is the episode title, which is routinely 'None'. Please share your code and the output you're getting in return.
Dave
