Help translating Airfoil to Airfoil Pro routine
Tue Mar 19, 2019 4:08 pm
colovin offline
I haven’t been able to update to 7.2.0 because it breaks the Airfoil plug in which I use daily to make announcements on my computer and to a remote speaker on the other side of the house. For some reason I just haven’t been able to wrap my mind around Airfoil Pro, I just can’t figure it out. It seems to complicate what is a simple process with Airfoil. I know it’s suppose to do a lot more but Airfoil does everything I need simply so I guess I’m a simpleton :-) But it’s keeping me at 7.1.1. I’m hoping that some one can translate one of my Airfoil routines into a Airfoil Pro routine so maybe I can see the light and do the rest of my routines in Airfoil Pro.
This is a trigger for a announcing temperature of 90 degrees first on the computer than on a remote speaker
airfoil: change audio source to indigoserver
execute embedded apple script
tell application "Play Sound" to play "Ultimate:Library:Application Support:Perceptive Automation:Indigo Server:Sound_Files:Weather:Temp90.aif"
airfoil: change audio source to play sound
set variable Temp90 to true
insert timestamp into variable: timetemp90
The first instance is playing a voice saying, "The Temperature is 90 degrees" on the computer, then it changes to and plays the message on the remote speaker. This is about as complicated as it gets. If anyone could translate this into Airfoil pro it might help me understand it.
An interesting note. I live in the desert. It's only played a few times but when the temp hits 115 the voice says "The Temperature is 115 degrees, Holly S##t" :-)
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Tue Mar 19, 2019 5:40 pm
Re: Help translating Airfoil to Airfoil Pro routine
I’m not at my Mac, but Pro has speaker groups so why not just play it to both speakers at same time?
Are they the only speakers you have? If so, just connect them all.
Thu Mar 21, 2019 9:20 am
Unfortunately I can't really follow what you're describing above given it looks like a mix of applescript and just textual description. A few points about the Airfoil Pro plugin:
  1. To trigger off of a source change, you do a device state change on the Airfoil instance's Source Name state.
  2. To change the source, use the Change Source instance action.
  3. The AppleScripts that talk to PlaySound will continue to work since they don't target the IndigoServer. I'm not sure that the PlaySound app is really necessary but because I don't understand what you currently have I can't say for sure.
