[SOLVED] Odd error messages
Mon May 01, 2017 4:34 am
jmdraper offline
Hi. Every so often when a trigger runs which turns the radio on (by streaming in iTunes then directing audio using AirFoil pro), the following set of errors occur. Most of the time the same trigger causes no issues. The error messages seem to relate to AirFoil Pro and Nest Home plugins but always trigger when the AirFoil Pro actions run so I am assuming it's related to that. This has the effect of hanging my Indigo server for a minute or so.
I don't even know how to interpret these logs to start trying to work out what's going wrong, or even what to try in order to isolate the error. Any help gratefully received!
Jon
29 Apr 2017, 11:53:02
   Action Group                    Toggle master bedroom audio
   Virtual Devices                 sent "Master bedroom audio" toggle
   Action Group                    Turn on master bedroom audio
   Trigger                         Tune iTunes to radio when client count > 0 and audio source is radio
   Action Group                    Tune iTunes to current radio station
   Action Group                    Radio source BBC Radio 4
   Error (client)                  timeout waiting for server response for request GetScriptFileList
   Error                           because embedded scripts execute sequentially they must complete their execution within 10 seconds.
   Error                           modify the script to exit quickly or convert it to an external file (not embedded).
   Stopping embedded script executor host (pid 86065)
   Error                           process (pid 86065) failed to quit after polite request -- forcing it to quit now
   Stopped "embedded script executor host"
29 Apr 2017, 11:54:45
   Z-Wave                          sent "Master bedroom speakers" on
   Script Error                    embedded script: ServerCommunicationError -- timeout waiting for response
     embedded script, line 2, at top level
StandardError: ServerCommunicationError -- timeout waiting for response
   Airfoil Pro Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 533, in runConcurrentThread
   Airfoil Pro Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   NEST Home Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 1884, in runConcurrentThread
   NEST Home Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mon May 01, 2017 4:37 am
jmdraper offline
Re: Odd error messages
By the way, if it helps, the Action Group "Radio source BBC Radio 4" that runs immediately before the first error runs a single line AppleScript as follows:
tell application "iTunes" to open location "http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio4fm_mf_p"
Mon May 01, 2017 10:51 am
If the AppleScript is embedded, then switch it to an external script - it's likely that iTunes is (for some reason) not responding to the script which is hanging up the server (embedded scripts have to run on the main server processing thread). Making it an external script will run it in it's own process so the server won't hang up waiting for the script to complete.
Wed May 03, 2017 2:42 pm
jmdraper offline
Great - thanks. I have given that a try and hopefully that will sort it. The wide range of seemingly random error messages put me off the scent a bit!
