[SOLVED]Airfoil Pro Issue
Posted: Mon Feb 06, 2017 8:01 am
I'm wondering if anyone can help me with this issue ...
I'm using Airfoil 5.5.2
Airfoil Pro plugin 1.0.7
Indigo 7.0.3
I've set up a scheduled action every morning to turn on my amplifier, open Safari and open a webpage at http://www.weta.org to stream their live classical music program and then another action to shut things off in the evening. I am using Airfoil Pro to stream the music to my home speakers using an airport express connected to the amp. However, I get the following error message from Airfoil:
Please include the following information when contacting Rogue Amoeba Support.
Domain: AudioHijackKitErrorDomain
Code: 5416
NSLocalizedDescription: Duplicate Application Running
NSLocalizedRecoverySuggestion: Safari cannot be launched, because a duplicate copy is already running.
You selected this version:
/Applications/Safari.app
However, another version is already running:
Two versions of the same application cannot run at once.
I've checked and can't find more than one instance of Safari on my computer. However, I do use a backup program called SuperDuper to clone my hard drive to an external hard drive. Could Airfoil think that's the other Safari instance?
I use an apple script to open Safari, which seems to work fine:
tell application "Safari"
open location "http://www.weta.org/listen-live"
end tell
Then I use another script at the end of the day to close Safari:
tell application "Safari" to close every window
quit
end tell
Sorry for the long post, but I hope one of the experts can help this amateur. Thanks.
Indigo 7.0.3
Code: 5416
end tell
quit
end tell
