For demonstration purposes, I'm gonna use iTunes as an example. Sorry for the lengthy code, but I just added a few lines so that the variable is created for you in Indigo for easier debugging.
- Code: Select all
tell application "iTunes"
set iTunesPlaylistRepeat to song repeat of current playlist as string
end tell
if not (variable "iTunesPlaylistRepeat" exists) then
make new variable with properties {name:"iTunesPlaylistRepeat", value:iTunesPlaylistRepeat}
else
if value of variable "iTunesPlaylistRepeat" is not iTunesPlaylistRepeat then
set value of variable "iTunesPlaylistRepeat" to iTunesPlaylistRepeat
end if
end if
end tell
Now when I run this in AppleScript Editor (I'm on Snow Leopard), it creates/updates the variable just fine in Indigo with the value "all". However if Indigo executes this script, it fills it in with "«constant ****kAll»". Obviously it's the constant and not the string value. Any ideas as to why?
I'm running the latest beta of Indigo.
