Some time back, I made a mod to _pageelem.html (added #if... after line 89) in Indigo 3 to allow embedding custom HTML in a control page item's captionName by omitting entityEncoding if the first character of the captionName was "<" (e.g. with an opening <div> tag). The same change works fine on Indigo 4 when a control page is viewed on a web browser.
However, on Indigo Touch the same control page is rendered without having executed my mod (i.e. entityEncoding has occurred and the name is not seen as HTML, but as plain text). Does the Touch app use a conventional HTML page and is it generated separately in the server from the web browser web page? Is there any obvious reason why this approach will not work with Touch? If not, is the server code user-modifiable and can you give me a clue where to find the right module? I spent a fair amount of time looking without success.
I'm using 4.0.0 b5 for both server and client.
Jeff
