- Code: Select all
def iphone_varlistpage(self, miniUI=kFalseStr, width=kEmptyStr, serverStatus=None):
Return Type: HTML page
if not cherrypy.server.indigoDb.AreControlPagesAllowed():
return self._ReturnControlDisabled(kHtmlPageStr)
self._ForceHeadersToNeverCache()
devList = cherrypy.server.indigoDb.GetDevices(cherrypy.server.indigoConn, True)
actionGroupList = cherrypy.server.indigoDb.GetActionGroups(cherrypy.server.indigoConn, True)
variableList = cherrypy.server.indigoDb.GetVariables(cherrypy.server.indigoConn, True)
if serverStatus == None:
serverStatus = _kConnectedStatusStr
if miniUI.lower() in [kTrueStr, u"yes", u"1"]:
tmpl = self._GetGlobalTemplate('iphone_varlistpage_mini.html')
tmpl = self._GetGlobalTemplate('iphone_varlistpage.html')
tmpl.serverStatus = serverStatus
tmpl.devList = devList
tmpl.actionGroupList = actionGroupList
tmpl.variableList = variableList
tmpl.width = width
return tmpl.RenderTemplate()
except (ic.ConnError, ic.InternalError, ic.ServerError), err:
return self._ReturnError(kHtmlPageStr, err.value)
except idb.ControlDisabled:
iphone_varlistpage.exposed = True
and add a iphone_varlistpage.html file like:
- Code: Select all
#filter $indigoCheetahFilter
<ul id="list" title="Variable list">
#set $cellColorClass = u'darkRowBg'
#for $variable in $variableList
#if $cellColorClass == u'darkRowBg'
#set $cellColorClass = u'lightRowBg'
#else
#end if
<li>$variable.name
#if $variable.value
<a>$variable.value</a></li>
#else
<a> </a></li>
#end if
#end for
</ul>
than you can make nice lists formatted for the IPhone
