This is a maintenance and bug fix release.
I cleaned up some of the code.
Removed the embedded up and down button images so they can now be replaced by replacing the images in the image directory.
Changed the tab order of the login page.
The application link changed to
http://host:8000/indigoflash/directory you created/main.html.
Added support for the Nokia N800. The 700 won't work because flash version 9 is required.
I'm still working on making the client skinable. It's more work then I thought. Flex can't use runtime css. So I have to build a class so that a user can change style elements.
Mike
