I have finally released my flex/flash client on sourceforge.net.
http://sourceforge.net/projects/coreautomation/
Right now its only the indigo client. The source code is available as well. Please give it 24 hours for the code to replicate to all mirrors if you are having trouble downloading it.
The quick instructions are, place the contents of the bin file under any directory you wish that the indigo web server serves content from. I suggest using Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/indigoflash and creating a directory of your choice.
The web link would then be http://indigohost:8000/indigoflash/the directory you created/core.html
Of course you don't have to host the client on the same system as indigo. Any web server will work. Password integration requires the indigo server though. If you host it somewhere else then you will have to login each time. You can even run it by launching the swf file from your main computer. Flash player 9 is required.
Please submit any bugs or request in the sourceforge forums so we don't pollute this forum.
Core 0.1.2 is out.
http://www.perceptiveautomation.com/php ... 2695#12695
Thanks again,
Mike
