Would like to create a test bed for development
Mon Nov 02, 2015 9:21 pm
JustJack offline
I would like to create a test bed for doing some indigo development. Something like the Demo Server that you can connect to on the client side. But I want to run it locally.
Is there a Insteon Device Simulator Plugin? Something that would let me create devices and create a virtual home environment I guess I would also need a Z-Wave device simulator.
Does the Demo Server have actual hardware connected to it because the more I think of it, it is probably exactly what I need, just a local copy.
Jack
Wed Nov 04, 2015 11:29 am
Re: Would like to create a test bed for development
The demo server is just like any other Indigo Server - its running on a colocated Mac. It doesn't have any interfaces connected to it. On Insteon/X10 devices, if you put "- sample device -" into the notes field, you can disable the Insteon/X10 interface but the device will continue to look/operate as if it's working. The line in the event log will look like this:
  Sent (offline)                  "office ceiling fan" set motor speed to high
for instance.
