unicode utf8 ...
Sun Apr 26, 2015 11:22 am
unicode utf8 ...
the following code:
p = subprocess.Popen("ps -ef  | grep 'for ((i=0' | grep /usr/bin/curl | grep -v grep",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE)
resp=p.communicate()[0]
indigo.server.log(resp)
In python in an indigo plugin and in a python shell launched from the indigo menu (should be both the same python version i.e. 2.6) produces different results:
in the first case I get
>>> " ....ther/grM-CM-<nTempera..."
and in the seconds case:
>>> "...ther/grünTempera..."
why is this different? and how can I get the 2. result in an indigoplugin?
I am stuck ..
Sun Apr 26, 2015 12:10 pm
Re: unicode utf8 ...
Not so sure this will help, but try changing the 2nd line to:
resp = unicode(p.communicate()[0])
Sun Apr 26, 2015 12:28 pm
nop...
the python shell launched from indigo should have the same python environment as the plugin :?: :?: :?: Or is there any environmental difference?
it is the SAME code
Anyway .. I am switching to a unique ascii identifier for the file names
Sun Apr 26, 2015 12:29 pm
I'd think they would be the same, but clearly they are not. I'll look into it...
Sun Apr 26, 2015 7:22 pm
RogueProeliator offline
That somewhat looks like it could be unicode in a different or unknown encoding format... it could be that your external Python has a different default encoding that is not coming through the Indigo Python environment? Again, this is a wild shot-in-the-dark, but try explicitly setting the default encoding:
sys.setdefaultencoding('UTF8')
Adam
