jholcomb wrote:Additionally, I cannot get the Heat Setpoint to report its status (always shows 0, even when in Heat mode). The control looks the same as the Cool Setpoint device state that works fine (except it is linked to Heat Setpoint).
Via the Indigo main window change the thermostat mode to Auto, then press the Refresh All button at the bottom-right of the window. The problem is the INSTEON thermostat won't send both SETPOINT values to Indigo unless the mode is set to AUTO. Once Indigo has a better idea as to what both SETPOINT values are, it can then increment/decrement them both even if the mode is not AUTO.
jholcomb wrote:Should both the set points be changed simultaneously? Seems like you would only want to change the cool setpoint when cooling (and heat setpoint when heating)
Possibly. I leave my thermostat in AUTO mode about 99% of the time, so I hadn't tried to make the COOL or HEAT modes smarter. You could do it by changing the action to a single Execute AppleScript action that checks the mode to determine what should happen, I think. The device has an attribute hvac mode which you will check for either heatOn, coolOn, or heatCoolOn (which is auto). You can then increment/decrement by changing the heat setpoint and cool setpoint attributes.
Regards,
Matt
