- Posted on
Sat Feb 09, 2019 12:17 pm
rlesperance
offline
Thank you so much ... This seem to be a very good option to consider.
Meanwhile, I have a problem with my Keyspan adapter. Until recently, I was working with the USA-28GX, the USB Twin Serial model. When you wrote to verify if I had the latest driver, I downloaded and installed, by error, the USA-19HS version, this one being a USB-A to Serial Adapter.
Since I don't have that adapter nor the serial cable that is required, I uninstalled it from the Keyspan app and tried to reinstall the USA-28GX, I am unable to reinstall it. I began getting an error message (see file attached) ... « Unable to install because there is already a newer version installed.» (translated from French).
I tried to uninstall the USA-28GX a second time, with the same result. I tried to get help from Tripp-Lite, but they were unable to help me.
I searched my hard disk to see if there was any remaining Keyspan file, without succes.
Can you help me ?
- Keyspan installation error.jpg (45.09 KiB) Viewed 2891 times
