[ANSWERED]: CM15A regular crash or reset ...
Posted: Thu Feb 11, 2016 8:50 pm
Hello,
After moving to El Capitan, I was obliged to replace my Keyspan adapter with the CM15A interface. I have a large house all wired with X10 devices. They have been working for years using the Keyspan adaptor. No real issue other than the Keyspan resetting problem after a power failure.
Now that I have moved to the CM15 A interface, I have 2 major issue:
• signals from the CM15A does not go through many of my X10 LM modules even if they are near the interface (there seem to be a difficulty to get the signal to the X10 LM modules, while all my wall transmitters work perfectly as usual)
• the CM15A crashes or resets regularly for no apparent reason
Could someone help me with these problems ... without trying to have me trash everything with ZWave or Insteon devices. As I said, all signals from almost 30 wall transmitters are received perfectly by all the X10 LM modules. The problem is having the CM15A interface to speak with the X10LM modules as they used to work with the Keyspan adapter.
Thanks in advance.
Robert Lespérance
Thanks in advance.
Robert Lespérance
