Error #: Device not found in active map.
Fri Jun 05, 2015 4:11 pm
Re: Error #: Device not found in active map.
Jay, I just mailed you my log from the day I was playing - see if it makes any sense or helps you?
I started working at my desk at 18:38 which is where you see me experimenting with Virtual Devices.
Fri Jun 05, 2015 4:54 pm
roquej offline
Running the latest version.
Fri Jun 05, 2015 6:10 pm
roquej offline
A quick update. Reloaded the Virtual Device plugin and the errors disappeared. Will report if they come back.
JP
Sat Jun 06, 2015 10:17 am
You mentioned that you may have duplicated a Device Group - did you do that immediately before the errors in the file you sent started happening?
Sat Jun 06, 2015 10:43 am
I hadn't touched or created any Virtual Devices until that day, so the duplicate process should be somewhere in that day's activity log.
I was working until tea time, so all playing took place from the 18:30 time period?
Sat Jun 06, 2015 11:19 am
Right, from the log I sent:
At 18:38 I created a new device 1808565961 and renamed it to Stufy Test. (Was supposed to be Study Test!)
At 18:41 I deleted it.
At 18:41 I created a new device 1803919337 and renamed it to vGroup Xmas Lights
At 18:46 I created a new device 1256984422 and renamed it to vGroup All Lights
At 18:52 I duplicated vGroup All Lights (1256984422) to a new device vGroup All Lights Copy (1215618871) and renamed it to vGroup Downstairs Lights
At 18:53 Device map errors for device 1765109646 started occurring (which is my Bedroom Lamp, which is in 'vGroup All Lights')
At 19:21 Device errors stopped.
I'm going to try and break it for you tonight, and re-send the logs with comments included. (And with those pesky WebServer requests disabled for the time being!)
Peter
Sat Jun 06, 2015 12:09 pm
Yippee!
Jay, I've just sent you a copy of my DB as of 10 minutes ago, together with todays log file.
It is currently in the broken state, throwing errors whenever I toggle my Study Light, which is a member of two of the vGroups. More explanation is in the email.
Peter
Sat Jun 06, 2015 2:39 pm
Got it. I'll have a look in the next couple of days.
Sun Nov 08, 2015 8:59 pm
dnomode offline
I'm getting the #943 error every time the last device from a virtual device turns off. Below is an example.
Nov 8, 2015 6:50:43 PM
  Received INSTEON                "Office" on
  Trigger                         All OFF Virtual Device - Button 3 ON
  Sent INSTEON                    "PowerLinc Interface" on (scene 30 - Keypad Linc Buttones)
  Sent INSTEON                    "Entry Keypad" on (scene 30 cleanup); no ack
  Sent INSTEON                    "Kitchen Garage Keypad" on (scene 30 cleanup)
  Received INSTEON                "Office" off
  Virtual Devices Error           Error #943: Device '611725409' not found in active map. Report  to support.
Any ideas why?
Thanks for your help
Edmond
Sun Nov 08, 2015 9:12 pm
dnomode offline
Hello All,
Forget my last question. I think the error was being created because I had deleted a device and re-added it to my configuration, however I did not re-add it to the virtual device. As soon as I added the device again to the virtual device the errors stop accruing.
I should have read the previous posts more carefully before asking the question. Sorry :oops:
Edmond
