Virtual Devices Error in Event Log
Posted: Wed Dec 04, 2013 9:54 pm
Hello-
Using Indigo 6.0.5 Pro... After duplicating a virtual device group, the following errors show up in the event log when I attempt to edit an actual device from the group (not the group itself):
Per the instructions, I'm reporting the error
- Code: Select all
Virtual Devices Error Error #943: Device '1480200676' not found in active map. Report to support.
Virtual Devices Error Error #943: Device '606275728' not found in active map. Report to support.
Virtual Devices Error Error #943: Device '1736705550' not found in active map. Report to support.
