Sound in response to a trigger
Wed Jun 16, 2021 4:52 am
Rene offline
If, at night, one of my motion sensors becomes active, I would like it to trigger a sound from my computer. Like a barking dog, or calling 'darling, is that you?'
Wed Jun 16, 2021 12:24 pm
ELWOOD offline
Re: Sound in response to a trigger
You can do this already, for a spoken announcement . In the trigger set up look at the bottom of the action window, in the speak line type in a line of text that you want spoken . Now when the trigger fires the compute will speak the text. As for playing an audio file I think you should be able to use a python script to play the audio.
My house has a few out side motion detectors that speak when motion is detected suck as "Hay there is some one coming up the driveway" and "There is someone at the front door" I have a temperature sensor on the barbecue that fires a trigger that says "the Bar B is now hot" this also starts a pester timer that waits about 2 hours and is the bar b is still hot it will say "Hay did you forget to turn off the Bar B. This repeats every 15 minutes until the Bar B has cooled down.
Elwood
Wed Jun 16, 2021 2:59 pm
glt offline
A low-code means to accomplish this would be using the "Run Shell Script" Action to call Apple's "afplay" command line with the path to your sound file supplied as an argument.
Server Actions -> Script and File Actions -> Run Shell Script
/usr/bin/afplay full_path_to_sound_file
Mon Aug 02, 2021 12:46 pm
ryanbuckner offline
Elwood
What kind of temp sensor do you have that can withstand that kind of heat?
Wed Aug 04, 2021 9:50 am
ryanbuckner offline
There are some solutions to have Alexa handle the announcement too, with a little python and a few variables
