Sensative Strips Comfort support
Thu Oct 15, 2020 5:31 pm
roquej offline
This is a Temperature and Luminence sensor.
https://sensative.com/sensors/strips-zwave/comfort/
I was able to include it, but not surprised that it needs a device definition. However, when going into the device there is no option to submit a device definition.
Any suggestion?
JP
Thu Oct 15, 2020 5:36 pm
Re: Sensative Strips Comfort support
We added support for that one back in 7.3. If it isn't working correctly then re-sync it and copy/paste the Event Log results into a reply. The version you have might have a different model ID than the ones for which we've added a definition.
Thu Oct 15, 2020 5:57 pm
roquej offline
As requested:
Z-Wave Syncing - started for "186 - Temperature"
Z-Wave Syncing - assigning return route to "186 - Temperature"
Z-Wave Syncing - retrieved manufacture and model names: Sensative - 019A, Multi Sensor (Strips Comfort) - 0003000A
Z-Wave Syncing - retrieved protocol version 4.54, app version 0.04
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v5 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "186 - Temperature" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved parameter 2 "LED blink during open/close" is false
Z-Wave Syncing - retrieved parameter 9 "Enable light reporting" is true
Z-Wave Syncing - retrieved parameter 4 "Temperature units" is 1 "Fahrenheit"
Z-Wave Syncing - retrieved parameter 3 "Sensor reporting frequency" is 1 "Normal"
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Thu Oct 15, 2020 6:49 pm
That looks good – it should be working.
Thu Oct 15, 2020 7:10 pm
roquej offline
Is not providing luminance and not providing the temperature in Fahrenheit.
As you can see from the log, it syncs fine. I have although excluded it and re-included it twice.
Any suggestions how to fix?
JP
Thu Oct 15, 2020 7:14 pm
roquej offline
So you can see, I have everything configured correctly. I think.
Sat Oct 17, 2020 6:33 pm
roquej offline
Never worked, so returned it.
