- Posted on
Fri Sep 21, 2018 9:07 am
jltnol
offline
So I'm going to probably not use all the right terms, but in schedules, actions, and triggers, at some point you get to Actions. Sometimes, there is only one action, but in other cases, more than one, and in some cases, lots of actions. I'm not sure what this particular window is called... but its window with the list of actions... you can "Add New", "Edit", "Duplicate, "Delete", and move an actions "Up" or "Down" in the list.
When you get to that window with lots of actions listed, some are 'delayed"... they are programmed by me to delay by a certain amount of time before the execute. But, with any list from 1 to ∞. there is no way to tell the order in which these actions will execute based on the delays I've programmed in. While I can easily re-arrange the list in the order actions will execute, its hard to do so because from the list view, I can't see how much each is delayed.
So in these windows with a long list of actions, the ability to Sort by Delay would be great, and even better the ability to Sort and SEE the amount each action is delayed by.
Make sense?
