Programatic UI Changes
Wed Jul 18, 2018 8:46 am
Colorado4Wheeler offline
I would really love to be able to change certain "fixed" UI components programmatically, like labels and button names. It would alleviate a lot of extra checkboxes that I have to use to hide or show certain things if I could just simply modify the text of a label or button on the fly. I understand a lot of this likely has to do with rendering the window initially based on the fields and widths but since there is a proliferation of feature requests lately (many from me) then I thought I would toss this in there.
And, yea, it's probably already on the list :roll: .
Wed Jul 18, 2018 9:29 am
mat offline
Re: Programatic UI Changes
More resources, but how about using a variable?
Late 2018 mini 10.14
Wed Jul 18, 2018 9:31 am
What UI components exactly?
Wed Jul 18, 2018 10:04 am
This is for the plugin API. Unless I've been on crack all this time and can change labels and buttons on the fly in my plugins :shock:.
Wed Jul 18, 2018 10:25 am
Not sure that this is completely on target, but here goes. Couldn't you call getDeviceConfigUiXml() (as an example), make changes to the XML as needed and then pass it back?
I did this in the latest versions of the GhostXML plugin to address a situation where a user could set a config value that's not in the "standard" set. If the value is not standard, the plugin returns a "Custom" option. The code might be a bit literal at this point, but it seems to work well.
Wed Jul 18, 2018 10:26 am
Ok, that's the scope (wasn't clear) - so what labels? You can change the button title on a menu item dialog by adding:
<ButtonTitle>Send</ButtonTitle>
to the MenuItem section:
   <MenuItem id="menu3">
      <Name>Override Server Version</Name>
      <CallbackMethod>overrideServerVersion</CallbackMethod>
      <ConfigUI>
         <Field id="versionNumber" type="textfield">
            <Label>Version number:</Label>
         </Field>
      </ConfigUI>
   </MenuItem>
Wed Jul 18, 2018 10:28 am
So I see Jay and I have a different spin on the question. :D
Wed Jul 18, 2018 10:32 am
<Field type="button" id="add" >
   <Label> </Label>
   <Title>Save Device </Title>
   <CallbackMethod>serverButtonAddDeviceOrAction</CallbackMethod>
</Field>
Then have something like:
valuesDict['add'].title = 'Delete Device'
Or
<Field type="label" id="mylabel" >
   <Label>Here is text I want to show on the UI form</Label>
</Field>
And change it with:
valuesDict['mylabel'] = 'Hello world'
Probably (does that reload in real time or next time device UI is opened?) but that seems like a lot more coding to get that done that to change the valuesDict that already shows the labels as objects.
Wed Jul 18, 2018 1:12 pm
mat offline
doh! i was miles off, thought you meant control pages - must get some sleep!!!
Wed Jul 18, 2018 3:17 pm
Once a dialog is running, the only thing that is bound to live data are the values displayed in the fields, so there's no current way to change those while the dialog is running. This isn't likely to change in the foreseeable future given the pervasive code changes that would be required.
You can make the dialogs more dynamic at load time however by using the above mentioned hook method.
Wed Jul 18, 2018 3:50 pm
I've needed this type of capability before as well a few times. I ended up just creating multiple controls and setting the visibility of the controls dynamically so that only the "correct" one is showing (sounds like you do the same already). But that can get cumbersome quickly if there are lots of permutations, of course.. So +1 for me on sympathy for the problem, but as Jay said it isn't likely to be implemented anytime soon given the nature of the changes that would be involved.
Wed Jul 18, 2018 3:59 pm
That's what I do if I need to manipulate before the form is loaded, just wanting to drop this request in the hat so I don't have to :).
Yes sir I do.
I'm actually writing a method to make my life much easier in that regard. I'm playing with it under the new 1.1 of HKB and it's actually pretty slick! Of course there are a lot of moving parts but it works much better than using a thousand checkboxes to get the job done.
Well, at least everyone is clear on the request and why I put it in "the box". ;)
