stop and start plugin
Wed Jul 18, 2018 11:03 am
RogueProeliator offline
Re: stop and start plugin
I did some some experimentation on this a while back whenever I had the WUnderground plugin writing a ton of columns and rows to a table... what it came down to is that changing a column type in Postgre in a high-volume environment is considered an unsafe operation.
Their recommended approach is to create a new table with the new structure, insert the data from old to new table, then drop old table and rename new. I started to look into adding this into the SQL Logger a while back but ended up abandoning it just due to lack of time and the infrequency that I encountered it.
Jay's point about transactional versus reporting structure is a very good point too... you could create basically a mini data warehouse -- update a non-SQL Logger table with data in the format you need for reporting, then trim off the transactional data in the SQL Logger's device table to a reasonable size/history.
Wed Jul 18, 2018 3:37 pm
A) the apple script is not depending on Indigo. If it works or not is a question for OSX. It runs completely outside indigo.
In a terminal it works like this:
osascript  /path to script/reloadSQLLogger.scpt
from indigo:
import subprocess
cmd = "/usr/bin/osascript /Users/karlwachs/indigo/reloadSQLLogger.scpt  &  "
subprocess.Popen(cmd, shell=True)
in an indigo action.
to avoid: "osascript is not allowed assistive access. (-1728)"
You need to give indigo and indigo server in "/preferences/ system/security" "assistive access"
B) I am happy with postgres and have otherwise absolutely no performance issues even with 32 GByte = 2 years of data
and the external script is:
activate application "Indigo 7"
delay 1
tell application "System Events"
   tell process "Indigo 7"
      tell menu bar 1
         click menu bar item "Plugins"
         tell menu bar item "Plugins"
            click menu item "SQL logger" of menu 1
            tell menu item "SQL logger" of menu 1
               click menu item "Disable" of menu 1
            end tell
         end tell
      end tell
   end tell
end tell
delay 30
delay 1
      tell menu bar 1
               click menu item "Enable" of menu 1
            end tell
         end tell
      end tell
   end tell
end tell
Wed Jul 18, 2018 3:57 pm
You will still be able to run that AppleScript from Indigo since it doesn't target the Indigo Server (no need for the python wrapper) - just run it as an external file.
Wed Jul 18, 2018 5:07 pm
the action actually looks like this: a little more that just call the applescript:
import time, subprocess, os
plug = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.sql-logger")
   sqlLoggerRestartTime = indigo.variables["sqlLoggerRestartTime"]
except:
   sqlLoggerRestartTime = indigo.variable.create("sqlLoggerRestartTime", "0")
lastRestart = float(sqlLoggerRestartTime.value)
if time.time() - lastRestart > 100:
   if plug.isEnabled():
      cmd = "/usr/bin/osascript /Users/karlwachs/indigo/restartWithDelaySQLlogger.scpt   &"
      indigo.variable.updateValue(sqlLoggerRestartTime,value=unicode(time.time()))
      indigo.server.log("restarting sql logger, last restart was "+ unicode(time.time() - lastRestart) + " secs ago")
      return
indigo.server.log("NOT  restarting sql logger, last restart was less than 5 minutes ago "+ unicode(time.time() - lastRestart) + " secs ago")
Thu Jul 19, 2018 10:51 am
Yes, well, if you make it more complicated then clearly it won't work... :roll:
We just keep seeing people proposing completely unnecessary workarounds for AppleScript and we want to make it clear that in those circumstances it doesn't have to be complicated. Deprecating AppleScript will be painful enough without making it worse for no reason.
