Add "room" awareness to each device
Fri Jul 06, 2018 3:48 pm
Re: Add "room" awareness to each device
You need to do two things. At plugin startup:
    def startup(self):
        indigo.devices.subscribeToChanges()
And then implement the routine to monitor changes:
    def deviceUpdated(self, oldDevice, newDevice):
        indigo.PluginBase.deviceUpdated(self, oldDevice, newDevice)
    # do something here
Fri Jul 06, 2018 4:15 pm
    # do something here
I'm not positive that it makes a difference, but you should probably use the super method to call the plugin's parent class's method:
    super(Plugin, self).deviceUpdated(oldDevice, newDevice)
    # do something here
If for no other reason, we might change the base class (or add another one) in the future so to migrate all you'd need to do is change it in the Plugin class definition.
Fri Jul 06, 2018 6:33 pm
mundmc offline
Good to know. Bookmarked.
