- Posted on
Sat Oct 10, 2015 9:00 pm
Gangotti
offline
A feature that I love using is the logic ability in conditions under triggers and schedules. Would it be possible to put it on devices as well? I recently ran into a issue when trying to turn on a keypad light. I wanted the light to turn on if either of my two lamps were on and turn off the light if both were off. in order to do this I had to create 4 triggers 2 (one for each lamp) that would turn the keypad light on if the lap was turned on and 2 (again one for each lamp) to turn it off. Without these rules if you activate the light from indigo, or from the touch client the light on the keypad would not come on. I for instance you could write a "rule" on the keypad device that said "if either lamp is on set keypad -button 3 to on" and keep the rule active as long as the lamps were on. once the lamps were turned off, the rule would no longer be true and the light on the keypad would turn off. This would effectively get rid of the 4 triggers I had t write in the above example and make it a property of the device. To go further you could then have Triggers/schedules/variables/etc, that could disable the rules giving you even more flexibility. Thanks for entertaining my thoughts, and thanks you for creating a great Home Automation Software.
