Page 5 of 24
Re: Integration with Amazon Echo
Posted:
Thu Aug 06, 2015 4:30 pm
by dproctor
Nope, it didn't work. below is the output. I'm using lambada basic execution as the role. I'm a complete newbie when it comes to this stuff. I'll have to read up on the portal to try and see what's going on. Again, thanks for your help.
"errorMessage": "Cannot find module './AlexaSkill'",
"errorType": "Error",
"stackTrace": [
"Function.Module._resolveFilename (module.js:338:15)",
"Function.Module._load (module.js:280:25)",
"Module.require (module.js:364:17)",
"require (module.js:380:17)",
"Object.<anonymous> (/var/task/index.js:22:18)",
"Module._compile (module.js:456:26)",
"Object.Module._extensions..js (module.js:474:10)",
"Module.load (module.js:356:32)",
"Function.Module._load (module.js:312:12)",
START RequestId: 7a86d1b5-3c89-11e5-9aaf-c7133b0c6464
Unable to import module 'index': Error
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object.<anonymous> (/var/task/index.js:22:18)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
END RequestId: 7a86d1b5-3c89-11e5-9aaf-c7133b0c6464
REPORT RequestId: 7a86d1b5-3c89-11e5-9aaf-c7133b0c6464 Duration: 23.04 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 27 MB
Posted:
Thu Aug 06, 2015 8:43 pm
by mreyn2005
Looks like perhaps you didn't zip the contents of src properly? AlexaSkill.js must be in the zip you upload to Lambda console, along with index.js and the node_modules directory. If you unpack your zip file, the src dir must not be included, just the files mentioned.
Matt
Posted:
Thu Aug 06, 2015 8:46 pm
by mreyn2005
manoncloud9 wrote:Here is the log file - sorry for the delay
Joe, looks like your having npm permissions issues.
http://lmgtfy.com/?q=38+warn+locking+Er ... ES%2C+openAt least one of the answers from the first 3 results should help you solve your problem. I recommend using NVM to avoid these sort of issues.
Matt
Posted:
Thu Aug 06, 2015 9:09 pm
by dproctor
mreyn2005 wrote:"errorMessage": "Cannot find module './AlexaSkill'",
That error message was for the hello world skill. Is the zip required for that skill? I just pasted the code rather than doing a zip.
Dave
Posted:
Thu Aug 06, 2015 9:11 pm
by dproctor
Matt
I just reread. What i did not include in the original zip for the ask indigo skill was the Node_modules directory. I only had the 3 file listed on your github. I guess that could be the problem then. I don't have time to test now but I'll try tomorrow. Thanks again for the help.
Dave
Posted:
Thu Aug 06, 2015 9:23 pm
by mreyn2005
- Code: Select all
Zip the following contents under askindigo/src/
askindigo/src/node_modules
askindigo/src/AlexaSkill.js
askindigo/src/index.js
Yeah you have to zip the helloWorld example, but it does not have a node_module directory included, because there are no external module dependencies in the example.
If you write/paste code in the online editor, you're essentially writing the equivalent of index.js. The only problem with this is approach is that you can not include any external modules. I needed to do digest auth and decided to use the external module 'http-digest', so I had to come up with a zip file instead of coding in the online editor. The helloWorld example provided is the 'Hello World" for how to do your own zip file.
Keep us posted.
Matt
Posted:
Sat Aug 08, 2015 1:42 pm
by mreyn2005
Posted:
Sat Aug 08, 2015 3:17 pm
by dproctor
I'm still having no luck. This is what i get with the hello world skill now.
"errorMessage": "Unexpected token ILLEGAL",
"errorType": "SyntaxError",
"stackTrace": [
"Module._compile (module.js:439:25)",
/var/task/index.js:17
var APP_ID = ‘amzn1.echo-sdk-ams.app.9b6233c8-29e8-4946-abce-0562f160c033’;
START RequestId: 8189410c-3e11-11e5-9251-2d338b228cb0
Syntax error in module 'index': SyntaxError at Module._compile (module.js:439:25) at Object.Module._extensions..js (module.js:474:10) at Module.load (module.js:356:32) at Function.Module._load (module.js:312:12) at Module.require (module.js:364:17) at require (module.js:380:17)
END RequestId: 8189410c-3e11-11e5-9251-2d338b228cb0
REPORT RequestId: 8189410c-3e11-11e5-9251-2d338b228cb0 Duration: 68.39 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 9 MB
Posted:
Sat Aug 08, 2015 4:50 pm
by dproctor
Matt,
I started over from scratch using your github and this is what I now get from the ASKindigo function:
START RequestId: ab023ab7-3e1a-11e5-87a3-5b7914920ff2
2015-08-08T22:13:16.704Z ab023ab7-3e1a-11e5-87a3-5b7914920ff2 session applicationId: amzn1.echo-sdk-ams.app.99eeb5c1-f1c6-4879-aa18-6ec54943c8d5
2015-08-08T22:13:16.705Z ab023ab7-3e1a-11e5-87a3-5b7914920ff2 dispatch intent = DeviceChangeIntent
2015-08-08T22:13:16.706Z ab023ab7-3e1a-11e5-87a3-5b7914920ff2 Device: Guest Bathroom Light
2015-08-08T22:13:16.706Z ab023ab7-3e1a-11e5-87a3-5b7914920ff2 Turning Guest Bathroom Light Off
2015-08-08T22:13:16.706Z ab023ab7-3e1a-11e5-87a3-5b7914920ff2 Making request:
http://rockyproc.asuscomm.com/devices/G ... method=put END RequestId: ab023ab7-3e1a-11e5-87a3-5b7914920ff2
REPORT RequestId: ab023ab7-3e1a-11e5-87a3-5b7914920ff2 Duration: 5000.25 ms Billed Duration: 5000 ms Memory Size: 128 MB Max Memory Used: 19 MB
Task timed out after 5.00 seconds
Posted:
Sat Aug 08, 2015 5:52 pm
by mreyn2005
Looks like everything is good except your Lambda function is timing out. I've set my timeout to 12 seconds, as the average runtime of my function is typically 5-9 seconds. Otherwise, everything looks good, assuming the Making request: url is correct?
See attached.
Matt
Posted:
Sat Aug 08, 2015 9:38 pm
by dproctor
So it has something to do with my router DDNS as it will always timeout the request, I tried unto 30 seconds. I then subscribed for a month of go prism just to confirm that it would work and sure enough it works fine with that. Any thoughts as to the issue? I have no issues logging into the DDNS url from outside my network.
Posted:
Sun Aug 09, 2015 3:05 pm
by dproctor
I've noticed now that alexa is only sending off device commands to indigo. Even though alexa correctly hears the "on" the indigo log shows an off command sent.
Posted:
Sun Aug 09, 2015 3:33 pm
by mreyn2005
I closed that issue yesterday:
https://github.com/msreynolds/askIndigo/issues/3Try updating the Intent Schema in the Amazon Developer Console's Interaction Model section with the latest from the repo.
Matt.
Posted:
Mon Aug 10, 2015 8:08 pm
by manoncloud9
I am confused on what steps I need to do on the developer portal do I create a lambda function first or a skill ? where do I get my app id to edit the index.js.
I am sorry I am not very versed in all of this.
Joe
Posted:
Mon Aug 10, 2015 8:14 pm
by dproctor
I did the lambada function first. You will get a line that has "arn:aws:lambda:us-east-1:your numbers here..." You use that in the skill on the developer portal. From the skill you make on the developer portal you will get the app ID.
