mreyn2005 wrote:Is your https endpoint using a self-signed cert? AmazonWS might not like that...
Matt
DVDDave wrote:Any other suggestions?
mreyn2005 wrote:...I will try my best to tackle the Upper Case issue this weekend, its documented here: https://github.com/msreynolds/askIndigo/issues/1...
Matt
I was also having trouble with spoken commands turning devices off but not on even though the test worked.
Let me know if you want my code for handling variables.
It would be great to Alexa respond with stuff like variables or status of devices. Is that something you are going to add in?
Make sure your Intent Schema contents are up to date. I had a bug in v1 of that schema, which caused On commands to not come through properly...
var upperCaseFirstLetter = false; // set this to true if you use Upper Case Device Names. Leave this false if you use lower case device names
var spaceBetweenWords = true; //default
var dashBetweenWords = false; //untested, let me know
var underscoreBetweenWords = false; //untested, let me know
GetVariableIntent what is {current energy use|VariableName}
GetVariableIntent what is the {current energy use|VariableName}
GetVariableIntent what is {current energy use|VariableName} value
GetVariableIntent what is the {current energy use|VariableName} value
GetVariableIntent get value for {current energy use|VariableName}
GetVariableIntent get the value for {current energy use|VariableName}
GetVariableIntent get the value for the {current energy use|VariableName}
GetVariableIntent what is the value for {current energy use|VariableName}
GetVariableIntent what is the value for the {current energy use|VariableName}
GetVariableIntent are the {sprinklers enabled|VariableName}
GetVariableIntent get value for {sprinklers enabled|VariableName}
GetVariableIntent get the value for {sprinklers enabled|VariableName}
GetVariableIntent what is the value for {sprinklers enabled|VariableName}
DVDDave wrote:...Does anyone have some insight into how this is supposed to work or what can be done to refine it?
You no longer will need to say
"Alexa ask indigo to turn on my kitchen light" instead you just say
"Alexa turn my kitchen light on"
One of my colleagues is contributing to this:
https://github.com/armzilla/amazon-echo-ha-bridge
Set up a fake Hue hub, listen for echo hue commands, forward to Indigo. I'll have an Echo on Tuesday to test it.
3. Did you see anything in the documentation that would suggest that the Echo could identify one user from another? It would be nice if my wife said "play my music" it would play a default playlist that she likes and when I said the same thing, it would know who uttered the command and play my playlist.
Ah, I found at least part of an answer. Creating multiple utterances for the desired leadin makes it a priority. For example, I created 10 samples of Get VariableName and now Get Test gets the variable instead of executing the action.
Any other insights?
