Ring flood/freeze sensor 05010101 usage in indigo
Wed Dec 01, 2021 12:49 pm
Butch2427 offline
I picked up a pair of Ring flood/freeze sensor's on amazon for $70. These seem well made and might actually survive getting wet. They even have a built in gasket. They included into Indigo 2021.1.2 with ease and show up as a notification sensor. They report battery status each hour without problem. I'm unable to receive the flood/freeze notification from the devices, nor will they respond on a status request.
Has anyone been able to get these working?
Z-Wave Indigo Device "KITCHEN SINK LEAK DETECTOR" Z-Wave Properties:
Indigo Z-Wave Version: 2021.1.2
Node ID: 82
Model: Notification Sensor
Model ID: 05010101
Manufacturer: Ring
Manufacturer ID: 0346
Protocol Version: 6.03
Application Version: 10.25
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 59v1 5Av1 5Ev1 9Fv1 20v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Features: routing, battery, beaming, waking
Neighbors: 14, 16, 22, 36, 42, 47, 48, 51, 58, 61, 62, 63, 64, 69, 70, 71, 72, 78
Associations: 1:[1]
Config Values: - none -
Amazon link: https://www.amazon.com/dp/B07MMTPWZ7?ps ... ct_details
Wed Dec 01, 2021 4:56 pm
Re: Ring flood/freeze sensor 05010101 usage in indigo
Thanks for the sync report – we'll add it to the queue to be supported. In the mean time take a look at this forum thread for creating a Trigger on the raw command for when water is detected. Let us know if that technique works.
Fri Dec 03, 2021 2:08 pm
Butch2427 offline
This does work. I created a trigger to look for the packet:
0x01 0x0F 0x00 0x04 0x00 0x51 0x09 0x71 0x05 0x00 0x00 0x00 0xFF 0x05 0x02 0x00 0x20
I wasn't able to "see" a reset transmission but that might be the device itself.
Thanks for the tip!
Thu Dec 16, 2021 12:02 pm
Indigo 2021.2.0 is now available and includes support for the Ring Flood/Freeze Sensor..
Sat Dec 18, 2021 5:53 am
explorer2324 offline
Can you tell me if I need to have the Ring Security System or does Indigo take its place?
Thank you,
Nat
Mon Dec 20, 2021 9:19 am
Hi Nat,
Indigo + a USB Z-Wave controller (Z-Stick, for example) is all you need.
Tue Dec 21, 2021 2:11 pm
Thank you. That is what I thought but I wasn't sure. After all these years I am still a basic user.
