ELWOOD wrote:You can do this already, for a spoken announcement . In the trigger set up look at the bottom of the action window, in the speak line type in a line of text that you want spoken . Now when the trigger fires the compute will speak the text. As for playing an audio file I think you should be able to use a python script to play the audio.
My house has a few out side motion detectors that speak when motion is detected suck as "Hay there is some one coming up the driveway" and "There is someone at the front door" I have a temperature sensor on the barbecue that fires a trigger that says "the Bar B is now hot" this also starts a pester timer that waits about 2 hours and is the bar b is still hot it will say "Hay did you forget to turn off the Bar B. This repeats every 15 minutes until the Bar B has cooled down.
Elwood
Rene wrote:If, at night, one of my motion sensors becomes active, I would like it to trigger a sound from my computer. Like a barking dog, or calling 'darling, is that you?'
