Refreshing Image Error
Fri Nov 17, 2023 9:29 am
ckeyes888 offline
I have a number of cams setup using SecuritySpy that when they lose connection with one I get a stream of error messages
in the log.
 Web Server Error                /web/refreshingimage: file not found or unavailable at 'http://192.168.1.80:8000/++image?cameraNum=4&width=640&height=480'
Maybe some way to suppress that error logging?
Carl
Fri Nov 17, 2023 10:25 am
Re: Refreshing Image Error
There is no way to suppress those messages. I'd recommend solving the root of the issue: why are those cameras going offline frequently enough for this to be a problem.
Fri Nov 17, 2023 7:34 pm
ckeyes888 offline
That’s really disappointing. There was a fix back in 7.2 by editing the indigoreqhandler file.
I would have hoped it was obvious that if I could keep the cam online I would.
So the analogy here is don’t fix the leaky roof…just keep it from raining.
Carl
Fri Nov 17, 2023 7:51 pm
That's an incorrect analogy: you can't stop it from raining, but you can figure out why your cameras keep falling off the network.
A better analogy would be to put buckets under the places where your roof is leaking rather than fixing the leak. :wink:
I've added a feature request that would cover this scenario so we'll see where it lands in terms of priority.
Tue Nov 21, 2023 1:48 pm
ckeyes888 offline
That’s an unfair assumption. You’ve never had a flakey piece of equipment or an issue with its implementation?
At the very least Indigo should just log the error once, not a steady, ridiculous flow of them hindering
all other entries.
Carl
