Can I use a UUID for a camera vs URL
Fri Sep 25, 2020 10:19 am
jroach offline
In my control page I am using the URL to access the camera. Can I use the UUID and if so what is the format?
If not, is it recommended to assign the cameras a static IP?
Sat Sep 26, 2020 3:13 pm
Re: Can I use a UUID for a camera vs URL
I'm not sure I understand the question, but if it is a URL to the Web Server built into the camera then the format of the URL will be totally dependent on how the camera has it defined.
Tue Sep 29, 2020 7:16 am
Different Computers offline
I don't know of any way to use the UUID to define a camera, except if you're using Security Spy. Even then, I think that only works for telling Security Spy where the camera is on the network, not where it is as a resource for an Indigo Control Page.
Sat Oct 03, 2020 11:52 am
jroach offline
DC, thanks.
So is the only way to lock in the camera is to make it a static IP address?
Matt,
I have it set that my cameras reboot every week. Occasionally they will bounce to another address and then get seperated from the Control Page.
Sat Oct 03, 2020 12:16 pm
FlyingDiver online
jroach wrote:
DC, thanks.
Matt,
Use a DHCP Reservation in your router/DHCP server, not a static IP address.
