Odd Trigger on Control Pages.
Sat May 18, 2019 6:39 pm
Sharek326 offline
So today for now reason at all something odd started happening on my control page.
I have a page setup called Utility Room. In that page are only 2 buttons for two devices.
1 for Oil Burner
1 For Utility Light Switch
If I click the light switch is toggles on and off the light
If I click the Oil burner it toggles on and off the oil burn and the light
I checked the event on the button and only 1 event for the oil burned toggle is listed. I even deleted the the event and added it back same result.
What happened?
Sat May 18, 2019 6:51 pm
Sharek326 offline
Re: Odd Trigger on Control Pages.
Further investigating it appears for some reason both devices got assigned the same address. Syncing seems to have fixed it. This is strange since I haven't even added anything to Indigo in months and it worked fine since I installed it.
Sun May 19, 2019 6:12 pm
Let us know if the problem happens again. It would be interesting to investigate the Event Log from around the time the problem starts occurring.
Sun May 19, 2019 9:11 pm
Sharek326 offline
Will do ....Just seemed odd since everything was fine and I haven't really done anything to Indigo at all in the past few months except the most recent update.
