Issue with Image
Posted: Wed Aug 08, 2018 3:21 pm
I'm pretty sure I'm missing something obvious here with a device image on my control pages.
Using the Honeywell Plugin, I want an Image to tell me if my heating is switched On or Off. No matter what image I use, it always uses the 'On' image, even though the heating is switched off.
I'm using systemMode from the Honeywell Evohome plugin, and currently the systemMode value shows as 'HeatingOff'
I've tried using an image with +HeatingOff on the end and still no change.
Image attached shows what an off/closed device should look like (Garage Door) as well as the text value for SystemMode and the button showing as On for heating.
