Time and Date on Control Page
Sun Dec 24, 2017 11:07 am
farberm offline
Can someone tell me what everyone is using to Display the Date and Time on the Control page.
Python script or something else.
If using a python script can someone provide an example
Thanks in advance
Sun Dec 24, 2017 12:19 pm
norcoscia offline
Re: Time and Date on Control Page
You can create variables for what you want to see and place them on your control pages - fill them by running the python code below. I run this just after midnight for things that change once a day. For time I use the built in Indigo function to update a clock variable (that is run once a min. -- second photo)
This is an example from one of my schedules
from datetime import date
indigo.variable.updateValue(972215514, date.today().strftime("%A"))  # substitute the ID of the variable that will hold the weekday
indigo.variable.updateValue(1274472235, date.today().strftime("%b"))  # substitute the ID of the variable that will hold the MonthShort
indigo.variable.updateValue(102740303, date.today().strftime("%B"))  # substitute the ID of the variable that will hold the Month
indigo.variable.updateValue(825743399, date.today().strftime("%d"))  # substitute the ID of the variable that will hold the Day
indigo.variable.updateValue(130393313, date.today().strftime("%Y"))  # substitute the ID of the variable that will hold the year
indigo.variable.updateValue(1578531574, date.today().strftime("%y"))  # substitute the ID of the variable that will hold the Year2Digit
You can sub in what ever format specifier you want from the list here
http://strftime.org/
PS. The format specifier are the bits in the red circle below.... Have fun and happy holidays
_______
Norm
Sun Dec 24, 2017 1:19 pm
farberm offline
I am a little new at this but I am going to make the following assumptions:
you created the following variable and they have the following variable numbers (listed in the variable window)
weekday - 972215514
MonthShort - 1274472235
Month - 102740303
Day - 825743399
year - 13093313
Year2Digit - 1578531574
Create s script that runs the python script you included but change the variable numbers to the ones I have and run it once a day at midnight
Sun Dec 24, 2017 1:45 pm
norcoscia offline
Yes - but your numbers will be different. Grab your numbers by right clicking on the variable name and copy ID
I sent you some files in native format - working through all of this does take some time but it is do-able :D
_______
Norm
Sun Dec 24, 2017 4:22 pm
mclass offline
Having (very) limited Python abilities, I have adopted an alternative approach:
    - Create two action groups DateUpdate and TimeUpdate
    - Each Action Group executes a Variable Action "Insert Timestamp into Variable" and inserts a formatted timestamp into variables : "TimeNow" and "DateNow"
    Screen Shot 1.png (57.41 KiB) Viewed 1624 times
    - "DateNow" is formatted (by the Action Group) by the string "%A %d %B %Y"
    - "TimeNow" is formatted by the the string "%I:%M %p"
    Screen Shot2.png (38.08 KiB) Viewed 1624 times
    - Each of the Action Groups are executed by schedules (time every minute, date at 12:01am every day)
    - Time and date variables are inserted to control page
<<EDIT>>
Forgot to add that I also added a trigger so that the time and date actions are executed on Indigo server startup to ensure the time and date variables are updated.
You could use a single action group and schedule that updated both at once (every minute) if you prefer. Hope that helps.
mclass
